did the server really stop? check system monitor to see if there is anything indigo running after you stop indigo
I had / have issues stopping indigo. only after indigo really stops and you manually start indigo I get mine to work ok.
matt (support) wrote:Have you tried a restart of the Mac itself?
matt (support) wrote:Hmmm... I'm not sure then. Are you running the script from the Script Editor application? Try running it from there as well as embedded in Indigo.
Can you command other applications like iTunes?
Here is a report of the same problem in Mavericks only with iTunes. A reboot ended up getting it working for that user.
jay (support) wrote:Look in the console log for errors when you run the script...
jay (support) wrote:Nothing with sandbox or guardian in the description? It might not necessarily have Indigo in the log message...
osascript -e 'tell application "iTunes" to play'
osascript -e 'tell application "IndigoServer" to log "hello there"'
matt (support) wrote:From the Terminal copy/paste these two lines individually:
- Code: Select all
Does iTunes start to play?
Does "hello there" appear in the Event Log?
Any errors?
Server:~ ddewey$ osascript -e 'tell application "IndigoServer" to log "hello there"'
35:52: execution error: IndigoServer got an error: Application isn’t running. (-600)'
matt (support) wrote:Try deleting Indigo off that Mac completely, then triple check to see if you have any older copies of Indigo on that Mac. If you do, then delete those as well.
After that, restart your Mac and then re-run the installer again. Maybe that will help unconfuse the OS...
