Plugin no longer working after update to 6.0.6
Sat Dec 07, 2013 8:32 am
Sevilsivle offline
EDIT: I have just seen the remark regarding serial communication affecting the DSC Plugin. I have performed the workaround suggested and can confirm this also helps with the RFXCOM Plugin.
I updated to 6.0.6 this morning and now the plugin fails to send commands to my Intertechno switches.
RFXCOM Debug Turn ARCAppliance Appliance/Dimmer On (level 0).
RFXCOM Debug Adres: 1
RFXCOM Debug housecode:C
RFXCOM Debug device type:ARCAppliance
RFXCOM Debug device type:1
RFXCOM Debug send x10 cmd: 7 16 1 7 67 1 1 0 (07 10 01 07 43 01 01 00)
RFXCOM Error send "Shed lights" on failed
these were working until I upgraded.
The Oregon sensors are detected as before the update
Is a download of 6.0.5 available anywhere so that I can go back to a working system?
Is the plugin still being supported? The bug I reported a while back concerning the battery status no longer being shown has not even been commented on.
regards
Tim
Sat Dec 07, 2013 2:23 pm
Re: Plugin no longer working after update to 6.0.6
Hi Tim,
I'm having trouble tracking down the exact reason this is failing. I know it is related to an update to the serial library, but I cannot reproduce it. A couple of questions:
1) Are you connecting to your RFX module directly via USB to your Mac?
2) What version of Mac OS X are you running?
Sat Dec 07, 2013 6:53 pm
This problem should now be fixed in Indigo 6.0.7.
Sun Dec 08, 2013 2:50 am
Sevilsivle offline
Hi Matt,
I have updated to 6.0.7 and everything works fine.
Perhaps no longer relevant but to answer your questions:
1. Yes directly connected via USB
2. Mavericks OS X 10.9 (13A603)
regards
Tim
