v1.02 - 2012-08-04
- Update for Mountain Lion support. There was an issue with decimal formatting of values which has been changed to float formatting.
hamw wrote:This is not a problem with the plug-in, but I had a couple of power outages which resulted in a spike of 39,000 kW being recorded and my TED 5000. Do you know of any way of editing this in the TED database? Or is there some other way doing this without wiping out all the data?
Starting plugin "TED 5000 Plugin 1.0.3" (pid 1251)
Started plugin "TED 5000 Plugin 1.0.3"
TED 5000 Plugin Your plugin version, v1.0.3, is current.
TED 5000 Plugin Error exception in deviceStartComm(TED 5000): global name 'flaot' is not defined
TED 5000 Plugin Polling Interval: 5
Bollar wrote:I just found this plug-in. Thanks!
I have an error on start-up that appears to let the plug-in update only once then stop:
- Code: Select all
Hopefully it's not just me.
bda wrote:I have the exact same error too!
Since day one. Would you like me to try something?
nlagaros wrote:Can you go to the main plugin configuration screen and save all settings. I added the version checker options there so perhaps it is in a funky state. I've seen this before when adding new configuration options. Thanks.bda wrote:I have the exact same error too!
