Prism reflector won't connect
Wed May 23, 2012 8:50 pm
bighop offline
I keep getting these error messages when I try to connect:
I don't know what I'm missing.
Picture 1.png (90.89 KiB) Viewed 2338 times
Wed May 23, 2012 10:26 pm
Re: Prism reflector won't connect
The permissions on a reflector key file are not correct. This can happen if you switch Macs and use Migration Assistant. Try the following:
1) Launch the Terminal application (inside /Applications/Utilities/)
2) Copy/paste the following line into Terminal. You will be prompted for your OS X admin account password, which needs to be entered so that all the steps complete successfully.
id
sudo bash
3) Copy/paste each line below *individually* and hit the return key after each one:
cd /Library/Application\ Support/Perceptive\ Automation/
cd Indigo\ 5/Preferences/PrismReflector
ls -al
chmod ugo-x *
chmod o-rwx *
chmod g-rw id_rsa
ls -al
id
4) Select all and Copy/Paste the entire contents of the Terminal window into an email or forum reply for me.
Thu May 24, 2012 7:14 am
bighop offline
Thank you, I will try that tongiht. I thought the problem was resolved: I was able to connect at home, its just away from home that the reflector reads down.
I just had this emac repaired, and they merged the data, so you are spot on.
Thu May 24, 2012 2:28 pm
bighop offline
Ok, I think I followed your steps... haven't had too much experience in the Terminal Window.
Here it is:
Password:
bash-3.2#
bash-3.2# cd /Library/Application\ Support/Perceptive\ Automation/
bash-3.2# cd Indigo\ 5/Preferences/PrismReflector
bash-3.2# ls -al
total 24
drwx------ 5 andrewhopkins andrewhopkins 170 Mar 6 19:12 .
drwxr-xr-x 7 andrewhopkins andrewhopkins 238 May 24 06:15 ..
-rw------- 1 501 501 883 Mar 6 19:12 id_rsa
-rw-rw---- 1 501 501 233 Mar 6 19:12 id_rsa.pub
-rw-rw---- 1 501 501 989 Mar 6 19:12 ssh_config
bash-3.2# chmod ugo-x *
bash-3.2# chmod o-rwx *
bash-3.2# chmod g-rw id_rsa
bash-3.2# ls -al
total 24
bash-3.2# id
uid=0(root) gid=0(wheel) groups=0(wheel),1(daemon),8(procview),2(kmem),29(certusers),3(sys),9(procmod),4(tty),5(operator),101(com.apple.sharepoint.group.1),80(admin),20(staff)
bash-3.2#
I have to say this is greek to me. If there is a specific thing I need to do, let me know. I can also contact the repair guy, Im sure he speaks this as well.
Thank you!
Thu May 24, 2012 2:42 pm
We can figure it out (and are close), but I need the Terminal results from step #2 above. In particular, the line that is:
id
Thu May 24, 2012 2:46 pm
bighop offline
This is what I got after step 2:
Last login: Thu May 24 16:26:32 on ttys000
mac-owners-emac:~ andrewhopkins$ id
uid=502(andrewhopkins) gid=502(andrewhopkins) groups=502(andrewhopkins),98(_lpadmin),80(admin)
mac-owners-emac:~ andrewhopkins$ sudo bash
Password:
bash-3.2#
Thu May 24, 2012 2:49 pm
Got it. From the Terminal do:
sudo bash
chown 502:admin *
then stop and restart the Indigo Server (via the Indigo 5->Stop Local Server menu item). It should then work correctly.
Thu May 24, 2012 3:04 pm
bighop offline
That did it!!!!!
I restarted Indigo in order for it to take effect, but it worked!
What was the deal?
Thank you!!
Thu May 24, 2012 3:07 pm
The file owner for some of the reflector key files was incorrect. It was your old user account and not your new one.
Thu Jul 26, 2012 6:00 pm
Chompy offline
Thanks for posting how to fix this issue. It resolved my prism reflector problem after installing Mountain Lion!
Tue Aug 07, 2012 5:44 pm
tompanderson offline
I ran through your steps and here is the result: Help?
Tom
Tue Aug 07, 2012 6:00 pm
Presuming you are running Indigo 5, do the steps below so I can see the results.
id
sudo bash
ls -al
chmod ugo-x *
chmod o-rwx *
chmod g-rw id_rsa
ls -al
id
Users browsing this forum: No registered users and 31 guests
