No, the protocols used by the RFXLAN are different from the RFXtrx433/RFXrec433
It seems there is a Belkin LAN-USB hub that can be used to connect the RFXtrx to a network but I don't know if the plug-in supports a TCP/IP connection.
b_weijenberg wrote:There should be no need to configure the protocols using RFXmngr.
It is prefered that the plug-in initializes the protocols used in the RFXtrx433/RFXrec433. I will check with the developer if this is implemented.
b_weijenberg wrote:Note that you have to connect the USB before you start RFXflash, the RFX is not detected if you start RFXflash and after that the USB.
RFXmngr can be started before you connect the USB.
Only 1 application can connect the RFX at the same time. If you have connected the RFX with RFXmngr than RFXflash will not detect the RFX.
b_weijenberg wrote:Please read the message posted by Matt Fri May 18, 2012 2:07 pm.
jay (support) wrote:You can install mono and try it - it worked for me after several attempts. Terrible user experience though given the mono bugs, etc...
