Forrest wrote:This plugin looks very interesting to me - I would like much better ability to control each zone independently rather than simply starting a watering cycle.
I've downloaded it, but can't figure out how to get it to do anything. Double-clicking on "MasterIrrigation.indigoPlugin" doesn't do anything. I searched through the package and found a file called "PluginConfig.xml" which seems to contain the information that's supposed to be in the opening screen, but in an xml format. I tried opening it in Safari, but didn't get anything like the screen shown in the users guide (same text, but no options to do anything with it).
What am I missing here?
You need to define a plugin type device for each of your zones, plugin: Master Irrigation, type: irrigation zone... then hit the configure button to set how long and how often it's supposed to run.
Unzip the plugin distribution and then double-click the MasterIrrigation.indigoPlugin. Indigo will present a dialog window, click Install and Enable.
Make sure you're running the latest Indigo release
Jun 10, 2014 23:24:58
Schedule Irrigation
Master Irrigation Starting schedule creation
Master Irrigation Error Irrigation schedule already running. Action request ignored.
Jun 10, 2014 23:25:30
Jun 10, 2014 23:29:36
Schedule Irrigation
Master Irrigation Stopping schedule
Master Irrigation Irrigation schedule was running. Now stopped.
Schedule Irrigation
Reloading plugin "Master Irrigation 1.0.1"
Stopping plugin "Master Irrigation 1.0.1" (pid 334)
Master Irrigation stopConcurrentThread called
Stopped plugin "Master Irrigation 1.0.1"
Starting plugin "Master Irrigation 1.0.1" (pid 28170)
Master Irrigation Log level preferences are set to "Verbose".
Master Irrigation Master Irrigation Plugin Initialized
Started plugin "Master Irrigation 1.0.1"
Master Irrigation Plugin Starting
Master Irrigation Your plugin version, v1.0.1, is current.
Master Irrigation No lock found. Set irrLock True
Master Irrigation Operating in test mode
Master Irrigation Schedule create, reading device: Arriere est
Master Irrigation Scheduled for today
Master Irrigation Schedule create, reading device: Cabanon
Master Irrigation Schedule create, reading device: Centre Arriere
Master Irrigation Schedule create, reading device: Centre Arriere Est
Master Irrigation Schedule create, reading device: Cote Est Avant
Master Irrigation Schedule create, reading device: Cote Ouest
Master Irrigation Schedule create, reading device: Escalier
Master Irrigation Schedule create, reading device: Fleur avant
Master Irrigation Schedule create, reading device: Fleur Driveway
Master Irrigation Schedule create, reading device: Gazon avant
Master Irrigation Schedule create, reading device: new device 1
Master Irrigation Error Error in plugin execution ExecuteAction:
File "plugin.py", line 161, in createSchedule
<type 'exceptions.KeyError'>: ('realIrrDevice',)
Jun 10, 2014 23:35:22
Script Error Device Summary.py: 'key com.berkinet.masterirrigation not found in dict'
Device Summary.py, line 9, at top level
KeyError: 'key com.berkinet.masterirrigation not found in dict'
kidney wrote:Cna't get my plugin to work anymore any help would be appreciated.
here is my log:
- Code: Select all
