Curious about something. When I check my location on the Maps app on my iPhone
it seems to be very accurate and updated every minute or two.
Is that the same info that the plugin is accessing for determining locations?
Carl
ckeyes888 wrote:Curious about something. When I check my location on the Maps app on my iPhone
ckeyes888 wrote:Thanks. So just to be clear, the fenced areas aren't currently active?
I do see them showing on the map, just no info returning when we're in one.
Carl
ckeyes888 wrote:Is there some reason that "Distance Away" isn't listed as a possible condition for use
in a trigger?
bschollnick2 wrote:ckeyes888 wrote:Is there some reason that "Distance Away" isn't listed as a possible condition for use
in a trigger?
Because I didn't think about it? I'll look into adding that shortly.
Dewster35 wrote:I use distance away to trigger... have been for awhile now and it's caused no problems until today. So my wife is out of town on a business trip... while she is 300 miles away, because she put her phone into airplane mode (I'm assuming), the location of her phone can't be found and it puts the distance away to 0. I'm sure I could cobble something together through insteon variables to pull the last distance away, but doesn't it make more sense when the plug-in can't locate the idevice that it simply makes the assumption that it is where it last lost location? I would think that makes more sense than assuming that they are 0 distance away. Thoughts? Any way you could work that into the next version?
This is a GREAT plug-in... was going to try the smartphone radar thing but since our whole house is apple'ly, the find my idevice works perfectly!
