iRed2 users, UNITE!
Tue Sep 27, 2011 12:24 am
tinbert offline
Re: iRed2 users, UNITE!
ckeyes888 wrote:
Hey,
I'm trying to mod this script to send the IR command to all LEDs.
I've been using it with "external" which has worked for all but one of my devices which for some reason only will work by sending from
iRed using "All LEDs"
The syntax for all is like here:
perform action (Code "next" of Device "Sony/Tuner") using module "Office" using led "all"
I assume that you have already tried out this syntax?
tin:b Software - maker of iRed*
Tue Sep 27, 2011 12:26 am
tinbert offline
dnomode wrote:
Hello Tinbert,
I am trying to use iRed2 to control my mitsubishi TV using RS-232 with the GC-100-12. I was not having any luck with iRed2 so I downloaded iTest and it works good, however I'm sending this style of command \xDF\x80p\xF8\x02\x00\x006. How do I send this type of command with iRed?
Ed
Hi Ted,
I was not aware that non ASCII-Codes are also used in RS232, so currently there is no way to enter these beasts into the respective field. I'll put this onto the wishlist.
Tue Sep 27, 2011 12:33 am
tinbert offline
ckeyes888 wrote:
I guess my above post could be better summarized by asking if
it's possible to send some codes to the external LEDs, and some to the internal
LEDs?
I don't understand. You are already using "external" and "internal" in your AppleScripts. Of course, you have to specify this for every code you want to transmit.
You can also target specific LEDs like here:
   perform action (Code "next" of Device "Sony/Tuner") using module "Office" using led 2
Cheers, Robert
Tue Sep 27, 2011 8:26 am
dnomode wrote:
Is anyone working on any plugins for IR control?
At one point forum user "Perry The Cynic" mentioned that he was working on a plugin for the Global Cache devices, but I don't know the status.
IR devices like the GC/IRtrans are high on our list of priorities for plugins - so I expect that after 5.0 ships and we start prioritizing next steps we'll evaluate what is currently available from 3rd parties and see if there are some holes we need to fill. Nothing to announce yet but just to let you know what the priority is.
Thu Sep 29, 2011 1:57 pm
The discussion of using Python to control the Global Cache devices was split off to a new thread.
Fri Sep 06, 2013 4:24 pm
ckeyes888 offline
Anyone using an iTach Wifi unit with iRed2 and Indigo?
Having an issue getting iRed2 to connect to it.
Carl
Fri Jul 03, 2015 12:11 pm
hamw online
IRed has worked very well for several years. However, while I still can send IR to IRed via the IR Trans, I seem to have lost the ability to send from Indigo scripts. Oddly, i looked and my tuner device and its codes were no longer in the iRed app, and I had to find an archived version of it. They are now back in IRed, and when I press a "test" button within the action window it will send the command to the IRTrans and work properly. However, my Indigo scripts no longer work. Here's what I've been using. These commands are executed in a trigger when a control page button press changes a variable.
Any advice would be appreciated. :D
using terms from application "IndigoServer"
   on RemoteControl(TheRemote, TheDevice, irCode)
      with timeout of 3 seconds
         try
            tell application "iRed2" to perform action Code irCode of Device TheDevice of Remote TheRemote
--I also tried this syntax based on Robert's advice above:
tell application "iRed2" to perform action (Code irCode of Device TheDevice) using module Remote TheRemote using led "internal"
         on error
               log "Error - Could not transmit to iRed2 --> Device: " & TheDevice & ", code: " & irCode using type "iRed:"
            end tell
         end try
      end timeout
   end RemoteControl
         if value of variable "WHA_Radio_Preset" is "1" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_1"
            RemoteControl("Sony Tuner", "Sony/Tuner", "1")
            RemoteControl("Sony Tuner", "Sony/Tuner", "Enter")
         end if
         if value of variable "WHA_Radio_Preset" is "2" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_2"
            RemoteControl("Sony Tuner", "Sony/Tuner", "2")
         end if
         if value of variable "WHA_Radio_Preset" is "3" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_3"
            RemoteControl("Sony Tuner", "Sony/Tuner", "3")
         end if
         if value of variable "WHA_Radio_Preset" is "4" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_4"
            RemoteControl("Sony Tuner", "Sony/Tuner", "4")
         end if
         if value of variable "WHA_Radio_Preset" is "5" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_5"
            RemoteControl("Sony Tuner", "Sony/Tuner", "5")
         end if
         if value of variable "WHA_Radio_Preset" is "6" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_6"
            RemoteControl("Sony Tuner", "Sony/Tuner", "6")
         end if
         if value of variable "WHA_Radio_Preset" is "7" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_7"
            RemoteControl("Sony Tuner", "Sony/Tuner", "7")
         end if
         if value of variable "WHA_Radio_Preset" is "8" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_8"
            RemoteControl("Sony Tuner", "Sony/Tuner", "8")
         end if
         if value of variable "WHA_Radio_Preset" is "9" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_9"
            RemoteControl("Sony Tuner", "Sony/Tuner", "9")
         end if
         if value of variable "WHA_Radio_Preset" is "10" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_10"
            RemoteControl("Sony Tuner", "Sony/Tuner", "0")
         end if
         if value of variable "WHA_Radio_Preset" is "11" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_11"
         end if
         if value of variable "WHA_Radio_Preset" is "12" then
            set value of variable "WHA_Radio_Display" to value of variable "WHA_FM_Preset_12"
         end if
   end tell
end using terms from
Sat Feb 20, 2016 11:58 am
Forrest offline
I apologize for asking this here, rather than on the iRed forums, but there is no recent activity over there, so I don't know if the software is even still supported.
I was using iRed2 with Indigo to control media equipment for a number of years, and recently upgraded my home automation computer to an older MacBook Pro (intel Core 2 Duo) running OS 10.11 (El Capitan). IRed2 crashed on launch, so I downloaded the newest version, and it now runs, but does not recognize either of my IRTrans transceivers. One is USB and the other is ethernet. IRedTouch on my iPhone accesses the network device just fine, so I know it is configured correctly and working.
I have a number of Apple Scripts in Indigo that I was using to control the A/V components through iRed2, so I'd like to get it working.
Any ideas?
Sat Apr 06, 2019 1:51 pm
RickStreet offline
iRed 2 was updated April 3, 2019!!! I downloaded the newest version. All is working great under Mac OS Mojave.
Rick
Rick
Thu Oct 24, 2019 8:37 pm
hamw online
I assume these Apple Scripps will no longer work under Indigo version 7.4? Therefore Indigo 7.4 breaks iRed as a communications interface?
Fri Oct 25, 2019 6:31 am
Not quite. You can still run external AppleScript files, but not embedded ApplesScripts. So scripts targeting the iRed2 application should still work.
Fri Oct 25, 2019 7:07 am
hamw online
But scripts like the ones above that use a variable to trigger an action will no longer work, correct?
Fri Oct 25, 2019 8:18 am
Correct. It would have to be rewritten in Python, but the Python script could call an external AppleScript if needed for the actual control of the iRed2 device.
Fri Oct 25, 2019 8:48 am
Yep, this is probably a good example of a script that can use the pyapplescript handler calling functionality to split it's functionality into the Python part, which performs the logic, and an AppleScript part which does the AppleScript calls (specifically, the RemoteControl handler in the script above).
Thu Jan 13, 2022 1:10 am
dtich offline
Has anyone taken a stab at an iRed2 plugin? Any beta versions kicking around? :D
A guy can dream.
Users browsing this forum: No registered users and 27 guests
