Question re Schedules
Fri Sep 02, 2011 8:41 pm
atlantaguy offline
I want my schedules to execute without having to have Indigo running. Can this be done thru the module only? I'm using the 2414U. Thanks.
Fri Sep 02, 2011 10:52 pm
Re: Question re Schedules
Yes, Indigo support uploading basic schedule logic to the 2414U. To see if your schedules are compatible with the 2414U choose the Upload Settings... menu item from the Interface menu. If the compatibility is only listed as okay or poor, then you can select the item to see why it isn't compatible with the 2414U's standalone capability.
Next, make sure the Enable checkbox column is checked for the schedules you want to upload, then press the Upload button.
If something doesn't work, then copy/paste from the Event Log window what occurs after you press the Upload button.
Users browsing this forum: No registered users and 20 guests
