0.7.27 Latest
Indigo 2023.2. API 3.4 Only
Remember - though need to reset up File Access permissions for these new 2023.2 IndigoServer and IndigoPluginHost apss
As per here:
With IndigoServer and IndigoPluginHost being new versions
Let Indigo manage aiohttp dependency and install as needed
Add increase error logging if incorrect buddy handle message fails to go (as per issue #14)
Change to logging if sql connection fails
Other changes:
0.7.20
Add requirements for Indigo API 3.4 Library install
0.7.16
Add error checking for missing Library
0.7.15
Dont reload model api call
0.7.14
Allow curly brackets { in reply
0.7.13
With Sonoma apple decided the iMsg database would store the message data in a Apple NSString Archived object. Taking up oodles more room.
It appears the plain text is quickly converted and then becomes NULL.
Update plugin to decode message.attributedbody using typedstream and decoded contents of NSString formatting.
