Clearing delayed actions for multiple devices in one command
Mon Dec 25, 2023 8:24 pm
durosity offline
I've been trying to rationalise and improve a lot of my sprawling python scripts, and I'm not sure if this is possible.
At present I have some action groups that run that have multiple lines for clearing device specific delayed actions, like so:
indigo.device.removeDelayedActions(monitor)
indigo.device.removeDelayedActions(lights)
indigo.device.removeDelayedActions(fan)
etc
I've been trying to find a way to get it into one single line. Most of what I've tried has failed on a syntax error. Closest I can find is:
indigo.device.removeDelayedActions(monitor),(lights),(fan)
but this doesn't seem to remove the delayed actions at all. Is this possible and if so what's the best way to do it?
Tue Dec 26, 2023 7:22 am
Re: Clearing delayed actions for multiple devices in one com
I'll answer by saying that you can't, and then show you how you can. :wink:
The command indigo.device.removeDelayedActions only accepts one argument at a time, and then clears all delayed actions from the target device. The command doesn't accept collections of devices (although I believe this feature may be on the list). You can iterate over a collection of devices, which takes a couple of lines--and it's the way I'd recommend doing it because it's more Pythonic.
device_list = (123456789, 987654321, 234567890)
for item in device_list:
    indigo.device.removeDelayedActions(item)
It's only three lines, and it's easy to see what's going on.
That said, you can use a little Python "trickery" using a List Comprehension, which compacts these operations down to a single line:
_ = [indigo.device.removeDelayedActions(item) for item in (123456789, 987654321, 234567890)]
Still relatively easy to understand, but the above code is way more obvious. The underscore is a common way to indicate a "toss away" value which is really only necessary to make Python syntax inspectors happy (not required).
Tue Dec 26, 2023 9:22 am
durosity offline
Ooooh perfect! That makes sense. I shall have a play with this later on. Much appreciated!
Wed Dec 27, 2023 10:52 am
ryanbuckner online
Dave, this forum totally need an up vote feature.
Wed Dec 27, 2023 11:03 am
Appreciated, but not necessary. I've received a metric ton of help on these fantastic forums and I'm happy to help out when I can.
Sat Dec 30, 2023 7:25 pm
durosity offline
Oh and this worked perfectly. And I’ve adapted it for use with a few other lines that were similarly setup! Many thanks!
Sat Dec 30, 2023 7:48 pm
Glad to help.
