Trigger not working - Water leak sensors
Sun Oct 29, 2023 7:43 pm
dlbeck offline
Since I’ve installed Indigo 2022 my email triggers have not been working. I previously used a Gmail password but switched to iCloud after Jay mentioned it would work better. But still no luck.
SMTP Host name: smtp.mail.me.com
Encryption: Start TLS
Server Port: XXX
Or is there a better way to get notified when devices states are changed like with water sensors? I used to get an email saying a device was triggered just like I set it up.
How can i confirm that email is working correctly with indigo? All I get now is that the server status is Failure. Thanks.
David
Mon Oct 30, 2023 12:28 pm
Re: Trigger not working - Water leak sensors
Reload the Email+ plugin and then watch for any errors that show up in the Event Log window.
Mon Oct 30, 2023 7:20 pm
dlbeck offline
Reloaded the plug-in….no luck
Tue Oct 31, 2023 5:59 am
What are you seeing in the log?
Fri Nov 03, 2023 9:09 am
dlbeck offline
I received an “Authentication failed” error
Fri Nov 03, 2023 9:57 am
Well, that's your answer. You probably need to generate a new app-specific password for logging into the iCloud mail account.
https://support.apple.com/en-us/102654
Sat Nov 04, 2023 10:52 am
ryanbuckner offline
For emergency type things like water leaks I don't find email to be immediate enough. I use the iMessage plugin to text me from an indigo specific iCloud account. I favorite the iCloud account in iMessage so messages always come through, even if I'm on DND.
Tue Nov 07, 2023 9:24 am
dlbeck offline
Thanks but it’s still not working.
The buddy SMS trigger looks rather complicated.
Back to my original question…what are others using to get notified for water leaks and other notifications?
Tue Nov 07, 2023 9:35 am
dlbeck offline
If gmail is a little wonky, is there another email platform I could use. My iCloud email might be creating an issue because its an alias to my real Apple ID. So maybe should try another option.
Tue Nov 07, 2023 10:14 am
Pushover to get iOS notifications. If it's something I really want to get my attention I will also use the notification feature of my Inovelli switches.
Tue Nov 07, 2023 10:37 am
I use actual SMS messages with Twilio. But it's not free, and it's a pain in the butt to set up now because of all the anti-SMS-SPAM requirements.
Email+ works fine for most users. iCloud definitely works, but you have to set it up correctly (with an app-specific password).
Tue Nov 07, 2023 12:44 pm
Dual offline
Pushover works great for me.
Tue Nov 07, 2023 7:03 pm
dlbeck offline
Thanks for the Pushover recommendation. Already up and going and it works great. :)
Wed Nov 08, 2023 7:22 am
Slightly late to the party here, but I use the email ==> SMS service from my mobile provider. I send email notifications from the Email+ plugin to my_mobile_number@vtext.com, and have the sender account added to VIP so it comes through 24x7.
The most common text I get is that someone left the closet light on.
