Forum rules
- Posted on
Mon Dec 12, 2022 10:42 pm
aldera
offline
Can this be added for a future update? It's an indoor single outlet plug. Thanks.
- Code: Select all
Indigo Z-Wave Version: 2022.2.1
Node ID: 211
Model: Relay Switch
Model ID: 7000B002
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 7.13
Application Version: 1.20
Model Definition Version: 0
Library Type: 3
Class Name: Relay Switch
Class Hierarchy: 04 : 10 : 00
Command Class Base: 25
Command Versions: 20v1 25v1 5Ev1 70v1 85v1 8Ev1 59v1 32v5 71v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Features: routing, beaming, energyMeter, powerMeter
Neighbors: 212
Associations: 1:[1] 2:[]
Config Values: - none -
- Posted on
Wed Dec 14, 2022 6:43 pm
matt (support)
offline
- Site Admin
I assume it is working okay currently?
- Posted on
Wed Dec 14, 2022 7:51 pm
aldera
offline
matt (support) wrote:I assume it is working okay currently?
Yes, it seems to be working right now.
