Is it possible to have two HassBridge instances running? I need to set up two different Home Assistant instances and would like to send some of my devices to one of them and the other devices to the 2nd install.
Is this possible somehow?
Running multiple instances of a plugin isn’t supported by built-in functionality, but you can hack it by duplicating the plugin and editing the Info.plist file inside the plugin bundle Contents folder:
<string>Rename this to something unique for Indigo’s UI</string>
<key>CFBundleIdentifier</key>
<string>Add a numerical 2 to the end of whatever is here so it is unique</string>
Since this isn’t an officially supported feature, I’d suggest trying it out in the trial version of Indigo to make sure it works for you.
