Weathersnoop v3.1 instead of 3.2.
Fri Jun 03, 2022 7:39 am
Ian offline
Hey Guys
A few questions........I have been using the weathersnoop plugin successfully since its inception
Anyhow....I am using Indigo 2022.1.1. I have weathersnoop plugin version 3.1 as I am using weathersnoop version 2.25 on my computer (Weather station is WMR200) which I dont believe is supported by higher version and plugin 3.2 does not support weathersnoop 2
was working OK until recently with a few Indigo changes.
the weather station is plugged into this computer directly (macmini2020.local or 192.168.0.94 in my case) and I am receiving data and serving it on port 8001 via http.
I have the plugin set to receive the same but getting an error message. Is this because this version (3.1) is python 2.7? Is that whats givng me the issues.? or is it a setup issue.?
this is what I am getting in Indigo.
WeatherSnoop Error Error getting station WMR 200A data
File "plugin.py", line 557, in update
f = urllib2.urlopen(theUrl)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 435, in open
response = meth(req, response)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 548, in http_response
'http', request, response, code, msg, hdrs)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 473, in error
return self._call_chain(*args)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 407, in _call_chain
result = func(*args)
File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 556, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
Fri Jun 03, 2022 7:48 am
boisy offline
Re: Weathersnoop v3.1 instead of 3.2.
As you noted, I removed WeatherSnoop 2 support from the 3.2.0 release of the WeatherSnoop Indigo plugin.
The error you're receiving is HTTP Error 404. This appears to be an error communicating with the WeatherSnoop 2 server.
What exactly changed between the time it was working and the time it failed? Did you update to 2022.1?
Fri Jun 03, 2022 5:35 pm
Ian offline
2 things changed......I had the weather station connected to a 11 year old imac. I was serving the weather via http on that iMac . The actual Indigo installation running the Automation is a Mac Mini. I was retrieving the data in Indigo by referencing the imac IP address and port and it was working OK......... The imac has been retired so I plugged the weather station directly in to the Mac mini and used its IP address and port in the Indigo setup and also upgraded the Indigo to 2022.1.1. Not sure which has caused the issue. FYI...I tried the IP address instead of "macmini2020.local". As you can see....Weathersnoop seems to be recieving the data from the weather station with no issues.
Screen Shot 2022-06-03 at 9.11.28 AM.png (157.82 KiB) Viewed 4952 times
Screen Shot 2022-06-03 at 7.28.51 PM.png (53.76 KiB) Viewed 4952 times
Screen Shot 2022-06-03 at 9.11.02 AM.png (194.18 KiB) Viewed 4952 times
Screen Shot 2022-06-03 at 7.25.24 PM.png (329.99 KiB) Viewed 4952 times
Screen Shot 2022-06-03 at 9.11.12 AM.png (408.36 KiB) Viewed 4952 times
Sun Jun 05, 2022 3:59 am
boisy offline
Everything seems to appear correct.
What do you see if you type this address in a browser on your Mac mini:
http://macmini2020.local:8001
Tue Jun 07, 2022 6:46 am
Ian offline
Screen Shot 2022-06-07 at 8.42.55 AM.png (167.33 KiB) Viewed 4909 times
Does not appear to be getting anything...tried 2 diffrenet browsers just to make sure. FYI...Obviously a Macmini (M1) and running OS 12.4
Screen Shot 2022-06-07 at 8.44.43 AM.png (293 KiB) Viewed 4909 times
Tue Jun 07, 2022 6:50 am
boisy offline
That explains why the plugin isn't getting data from WeatherSnoop 2. For some reason, the web server isn't running.
The Mac mini is running both Indigo and WeatherSnoop 2. Try this in Terminal:
curl -vvv localhost:8001
Do you get a response?
Tue Jun 07, 2022 12:00 pm
Ian offline
This what it returned
Screen Shot 2022-06-07 at 1.56.48 PM.png (106.21 KiB) Viewed 4887 times
Tue Jun 07, 2022 3:06 pm
boisy offline
Alright, now type this in Safari:
http://localhost:8001
What happens?
Tue Jun 07, 2022 3:19 pm
Ian offline
Nothing happens after I type it in....just a blank screen in Safari. Other websites do load so def connected.
Result
Screen Shot 2022-06-07 at 5.12.11 PM.png (427.66 KiB) Viewed 4869 times
Entry
Screen Shot 2022-06-07 at 5.11.57 PM.png (196.53 KiB) Viewed 4869 times
Safari
Screen Shot 2022-06-07 at 5.11.46 PM.png (203.26 KiB) Viewed 4869 times
Tue Jun 07, 2022 3:22 pm
boisy offline
Ok, I think the WeatherSnoop 2 server is working, but only if you access it via localhost.
Can you setup your Indigo WS2 plugin to use localhost instead of the macmini2020.local and see if that makes a difference?
Tue Jun 07, 2022 3:36 pm
Ian offline
I tried with localhost and also the IP address but no change unfortunately after I reloaded the plugin.
Screen Shot 2022-06-07 at 5.34.13 PM.png (289.07 KiB) Viewed 4855 times
Tue Jun 07, 2022 4:00 pm
boisy offline
I'm out of ideas, Ian. Sorry.
Thu Jun 09, 2022 2:59 am
I know nothing about Weathersnoop but can you try IP 127.0.01 which is equivalent to localhost?
