SQL Logger poll
How do you use the SQL Logger plugin?
4
10
3
12
Tue Feb 08, 2022 2:15 pm
SQL Logger poll
We're trying to gauge how many users use this plugin and which databases most users use as the backend. Feel free to comment below describing how you use the data logged to the database.
[EDIT] apparently, Tapatalk decided polls weren't useful. However, there is one attached to this post, so please open in a browser and vote, it would be much appreciated. And another good reason to not use Tapatalk... :P
Tue Feb 08, 2022 3:05 pm
Re: SQL Logger poll
I use my own custom CSV logging. :)
Tue Feb 08, 2022 8:03 pm
Dual offline
Re: SQL Logger poll
Same as Dave. I just do CSV files.
Wed Feb 09, 2022 4:24 am
McJohn offline
Re: SQL Logger poll
Almost 9 years now "With SQLite" to feed IndgoPlotD data.
Wed Feb 09, 2022 8:36 am
Re: SQL Logger poll
I have switched to Postgres some time ago
Wed Feb 09, 2022 9:13 am
autolog offline
Re: SQL Logger poll
I use it with Postgres. :)
Wed Feb 09, 2022 11:11 am
Re: SQL Logger poll
Did you forget to do the poll? There's no votes for SQLite.
Wed Feb 09, 2022 3:31 pm
Re: SQL Logger poll
The poll doesn’t show on Tapatalk and there’s no mention in the first post that a poll actually exists.
Wed Feb 09, 2022 5:26 pm
Re: SQL Logger poll
I edited the initial post to mention the poll. Shame on Tapatalk (which I don't use)...
Thu Feb 10, 2022 11:51 am
Re: SQL Logger poll
Fri Feb 11, 2022 4:26 pm
siclark offline
Re: SQL Logger poll
I think SQLite option should be removed as causes so many problems that Postgres doesn’t have.
Having said that, most of my logging and charting is influx into grafana.
Sat Feb 12, 2022 10:46 am
ryanbuckner offline
Re: SQL Logger poll
I use it with PostGres
Wed Feb 16, 2022 10:53 am
RogueProeliator offline
Re: SQL Logger poll
If you don't mind, what version of Postgres are you guys using?
Wed Feb 16, 2022 12:21 pm
Re: SQL Logger poll
Right after taking this poll, I did some investigating and discovered that I USED to use the plugin, but I had for some reason stopped and the implementation I had wasn't working any longer.
However, in looking at what it could do, I realized I could reimplement what I needed more easily than I had done before, and now I'm using it again. With SQLite for the log triggers only. So that's one poll change you'll have to account for manually, since I can't change my vote, apparently.
Sun Jun 05, 2022 3:10 am
Turribeach offline
Re: SQL Logger poll
This is my version (find out using "SELECT version();":
PostgreSQL 11.1 on x86_64-apple-darwin, compiled by Apple LLVM version 6.0 (clang-600.0.54) (based on LLVM 3.5svn), 64-bit
But I was looking to upgrade Postgres since I use it for other things too. Any known issues with the SQL Logger Plugin if I move to Postgres 14? Thanks!
