New Plugin - Flair Smart Vents
Sun Jul 18, 2021 10:30 am
Re: New Plugin - Flair Smart Vents
https://github.com/FlyingDiver/Indigo-F ... /tag/0.0.5
Now supports creating puck devices for use as temperature and humidity sensors.
Please report any issues before I release on the plugin store.
Sun Jul 18, 2021 11:35 am
bdubnm offline
Got this error after upgrading to 0.0.5
Jul 18, 2021 at 11:29:43 AM
   Disabling plugin "Flair 0.0.5"
   Stopping plugin "Flair 0.0.5" (pid 53196)
   Stopped plugin "Flair 0.0.5"
   Enabling plugin "Flair 0.0.5"
   Starting plugin "Flair 0.0.5" (pid 53206)
   Started plugin "Flair 0.0.5"
   Flair Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 219, in runConcurrentThread
KeyError: u'4e213f6d-b326-5816-b038-f8867e8e6287'
   Flair Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I also received the following error after adding a Puck...
  File "plugin.py", line 208, in runConcurrentThread
NameError: global name 'TEMPERATURE_SCALE_PLUGIN_PREF' is not defined
Not sure if I need to remove all my previous Flair devices and start over. Please let me know.
Sun Jul 18, 2021 11:43 am
Delete any HVAC devices you created.
Sun Jul 18, 2021 11:56 am
bdubnm offline
1) I removed all Flair devices and disabled the plugin.
2) Reinstalled 0.05. as I had moved back to 0.0.4
3) Added my Flair Account - Went Green
4) Added a puck and got the following error...
Jul 18, 2021 at 11:50:01 AM
   Reloading plugin "Flair 0.0.5"
   Stopping plugin "Flair 0.0.5" (pid 53704)
   Starting plugin "Flair 0.0.5" (pid 53811)
5) Went to add a vent and only 1 of 14 were visible to add. The other 13 were not visible in drop down connection.
6) Going to remove Flair devices again and then completely remove the plugin from OS directory so I can reinstall that way.
Sun Jul 18, 2021 11:57 am
Hmmm. Very strange. Works on my system with one puck and one vent.
Sun Jul 18, 2021 11:59 am
Oh, wait. Open the plugin config dialog and set your preferred temperature scale. I just made a change to set a default scale.
Sun Jul 18, 2021 12:00 pm
bdubnm offline
I had previously done that. Temperature was set to Fahrenheit.
Sun Jul 18, 2021 12:04 pm
Sun Jul 18, 2021 12:12 pm
bdubnm offline
Upgraded to 0.0.6
1) Removed Devices
2) Upgraded plugin
3) Added Flair account
4) Added Puck - No Errors
5) Puck Returned temperature in F
6) Went to add the vents, only one vent is showing up in drop down picker (see screen shot)
Screen Shot 2021-07-18 at 12.12.15 PM.png (47.4 KiB) Viewed 3237 times
Sun Jul 18, 2021 12:14 pm
bdubnm offline
Corresponding Debug Log...The plugin gets the list of vents from Flair, but appears the drop down picker is only presenting a single value.
Flair                           new device: Starting FlairPuck Device 241640286
   Flair Debug                     new device: Fetching /api/structures/24628/thermostats
   Flair Debug                     new device: Fetched 1 thermostats records
   Flair Debug                     new device: Fetching /api/structures/24628/rooms
   Flair Debug                     new device: Fetched 7 rooms records
   Flair Debug                     new device: Fetching /api/structures/24628/pucks
   Flair Debug                     new device: Fetched 2 pucks records
   Flair Debug                     new device: Fetching /api/structures/24628/hvac-units
   Flair Debug                     new device: Fetched 0 hvac-units records
   Flair Debug                     new device: Fetching /api/structures/24628/vents
   Flair Debug                     new device: Fetching /api/vents/56bcc551-8296-5ede-90cf-c08f3eb63146/current-reading
   Flair Debug                     new device: Fetching /api/vents/f52a17ba-4e65-5df7-18b0-707d57cd98e0/current-reading
   Flair Debug                     new device: Fetching /api/vents/9f7acab8-319f-5ae3-4ec7-93acfb39551b/current-reading
   Flair Debug                     new device: Fetching /api/vents/4e213f6d-b326-5816-b038-f8867e8e6287/current-reading
   Flair Debug                     new device: Fetching /api/vents/38d289ff-3ba4-5f1c-618e-4a80a8949741/current-reading
   Flair Debug                     new device: Fetching /api/vents/26720a40-c5c4-536d-2fb5-ebd34df1522c/current-reading
   Flair Debug                     new device: Fetching /api/vents/6823a71c-9eb8-5b6d-f1b1-d0c7530fa384/current-reading
   Flair Debug                     new device: Fetching /api/vents/e74c3f84-003e-5117-ec38-95634f17abec/current-reading
   Flair Debug                     new device: Fetching /api/vents/01340ffd-8409-5aea-1532-f84226741604/current-reading
   Flair Debug                     new device: Fetching /api/vents/358e9861-6b09-5164-e18a-26fd2ec41505/current-reading
   Flair Debug                     new device: Fetching /api/vents/3693484e-763b-5166-af63-ed4ecdb7003d/current-reading
   Flair Debug                     new device: Fetching /api/vents/bd8887e8-4638-5e3e-75e6-d0bbf3974030/current-reading
   Flair Debug                     new device: Fetching /api/vents/a2406f42-9487-542b-94ba-29fbfc1e543a/current-reading
   Flair Debug                     new device: Fetched 1 vent records
Sun Jul 18, 2021 12:16 pm
Put the debug log and the data dump (menu command) in this GitHub issue: https://github.com/FlyingDiver/Indigo-Flair/issues/2
Followup there.
Sun Jul 18, 2021 12:22 pm
bdubnm offline
Full Debug log and screen shot uploaded to git issue.
Fri Apr 15, 2022 9:53 am
Plugin has been discontinued.
