Doesn't work with Signe Table Lamp
Thu Sep 03, 2020 7:02 pm
paulkaliciak offline
Hi - I was just wondering if you planned to support the Hue Signe Table Lamp in Hue Lights? I didn't realize that you supported the Signe Floor Lamp, because I would have thought they operated so similarly that that would have enabled Table Lamp functionality as well.
Paul
Thu Sep 03, 2020 7:23 pm
nsheldon offline
Re: Doesn't work with Signe Table Lamp
Hi Paul.
Thanks for the report. Please provide some debug logs so I can add support. To get debug logs, go to the Plugins menu -> Hue Lights -> Toggle Debugging. Let the log go for about 10 seconds then turn off debug logging the same way. Copy and paste the debug logs in your reply or in a private message. Let me know the name you’ve given the Signe Table Lamp so I can find it in the log.
Tue Mar 16, 2021 7:28 am
marketability offline
Hi
sorry but I created a new post by mistake - with the device ID if that helps
Cheers
Peter
Tue Mar 16, 2021 11:05 am
nsheldon offline
Hi Peter.
Thanks for the report. Philips don't provide details on new products any longer. So I need to know what capabilities the light has as well as the exact model ID. This can usually be obtained from within the Hue app on your mobile device. A screenshot of the new light details that shows the Model and device type and name would probably work.
Tue Mar 16, 2021 11:34 am
I've attached a screenshot from the app - its a white and colour ambience product if that helps
Model ID: 4080148P9
Here is a link to the Philips product page https://www.philips-hue.com/en-gb/p/hue-white-and-colour-ambiance-signe-table-light/4080148P9
Tue Mar 16, 2021 11:38 am
BTW... I manually edited the devices py file and it's working fine as far as I can tell
Wed Mar 17, 2021 12:20 am
nsheldon offline
Perfect! Yes, knowing that it's a color and "ambiance" (color temperature support) light does help. Thanks. I'll add it to the supported-devices.py file in the next patch release of the plugin. I'm glad you were able to add it to that file and verify it's working as well. That's helpful.
Wed Mar 17, 2021 1:09 am
Hi (again) looks like Philips have done it again and released a new version of the dimmer that dissent appear to be compatible
I can't see a way to confirm the device ID but I thinks it is "929002398602"
will trying adding it manually and let you know
Cheers
Wed Mar 17, 2021 1:26 am
nsheldon offline
Hey Peter.
Sounds good. Worst case, you can temporarily enable debug logging (Plugins menu -> Hue Lights -> Toggle Debugging) and I can find the new light from those logs (assuming you provide the name you've assigned it in the Hue app).
Wed Mar 17, 2021 1:35 am
sorry but that didn't work - any suggestions on ways to find the ID?
Wed Mar 17, 2021 1:43 am
Here is the log file with debug on - hope that helps
The switch is called "Lounge Dimmer" but I can't find that text string in the log BTW
Thanks again
01.txt
(20.63 KiB) Downloaded 119 times
Wed Mar 17, 2021 10:18 am
nsheldon offline
Hi Peter.
Oh! It's a new dimmer switch! I misread that as a dimmable light. Thank you for the debug logs. Unfortunately, because of how frequently the Hue Lights plugin queries the Hue bridge for sensor updates (once per second), to keep debug logs from growing uncontrollably fast, it doesn't log sensor response data from the bridge even in debug logging mode. I may need to look into alternate solutions, though, for situations like this since the Hue app, as you noted, doesn't show model IDs for "accessories" any longer.
However, do you have your Hue devices synced with HomeKit so you can access them in the Home app? If so, you can still find the model ID of all your accessories by long-pressing the switch within the Home app. That will bring up the settings in HomeKit for that switch. Scroll to the bottom and you'll see the "Model" listed. That's the information I need. You can also try adding it yourself to the supportedDevices.py file in the "kSwitchDeviceIDs" list.
Wed Mar 17, 2021 12:47 pm
Thanks for this... Homekit shows the model to be "RWL022"
MUCH appreciated!
Wed Mar 24, 2021 12:52 am
nsheldon offline
Version 1.7.47 Posted
  • Added support for the Hue Single color table light.
  • Added support for a new Hue Dimmer Switch.
  • Added support for the Osram Smart + LED GU5.3 reflector.
  • Added support for 2m and 5m Hue Outdoor Lightstrips.
  • Added support for the Hue Amarant Wall Washer light.
  • Added support for the Hue white candle dimmable bulb.
