My People Scripting Examples
Thu Dec 24, 2020 2:48 pm
whmoorejr offline
I will try to post any scripting examples that work with the MyPeople plugin here to help others. Feel free to contribute if you have one that works.
Bill
My Plugin: My People
Tue Jan 26, 2021 12:47 pm
whmoorejr offline
Re: My People Scripting Examples - Update state
Use this script to update the state of a MyPeople Person device....
import logging
myPeopleId = "com.whmoorejr.my-people"
myPeoplePlugin = indigo.server.getPlugin(myPeopleId)
if myPeoplePlugin.isEnabled():
   newPinNumber = "5678"
   myPeoplePlugin.executeAction("setUserPinNumber", deviceId=946349721, props={'userPinNumberField':newPinNumber})
   indigo.server.log("Didn't Work" , level=logging.WARNING) # log a failure message
Hint:
    Change deviceId # to the deviceId# of your device
    All of the device states are called by "set" from a "field"
    for userPinNumber setUserPinNumber userPinNumberField
    for firstName setFirstName firstNameField
    for phoneNumber1 setPhoneNumber1 phoneNumber1Field
    etc.
Bill
Tue Jan 26, 2021 12:49 pm
whmoorejr offline
Re: My People Scripting Examples - PIN Code use
This can be used with a control page keypad on any method where you can get a PIN number saved as a variable... This example is used in a trigger that fires when that variable changes.... In this example:
    Variable: "PWInput" [777599449] is the variable set from a control page keypad (or whatever method you choose to populate the variable)
    Variable: "Outcome" [748482965] the variable that is updated at the end of the scrip with the name of the person.
    Action Group (12345678) the action that is run with a successful PIN code.
    Action Group (87654321) the action that is run with a failed PIN code.
import logging
login_name = "PIN fail" # if you change this, don't forget to update the if login_name == "PIN fail" below
password = indigo.variables[777599449].value # "PWInput"
theMessage = "Unsuccessful PIN Entry Attempt with PIN: " + password
for dev in indigo.devices.iter(filter="com.whmoorejr.my-people"):
   MyPin = dev.states["userPinNumber"]
   if MyPin == password:
      login_name = dev.states["friendlyName"]
      theMessage = "PIN Code Accepted, " + login_name + " is here."
#      indigo.server.log(login_name + " can have soup!") # log a success PIN message
#      indigo.actionGroup.execute(12345678) # run a success PIN action
if login_name == "PIN fail":
   indigo.server.log("No Soup For You!", level=logging.WARNING) # log a failure message
#   indigo.actionGroup.execute(87654321) # run a failure PIN action
indigo.variable.updateValue(748482965, value=login_name)  # update variable with name of user with matching pin or "PIN Fail"
indigo.server.log(theMessage) # log the result of the script
Bill
Tue Jan 26, 2021 12:53 pm
whmoorejr offline
Re: My People Scripting Examples - Specific Now Showing
Use this script to set the "Now Showing" device to a specific device (record/person).
import logging
   theRecord = "1"
   myPeoplePlugin.executeAction("nowShowingSpecific", deviceId= 1883703450, props={'nowShowingSpecificField':theRecord})
Notes:
    Change theRecord = "n" to the record number you want.
    Change deviceId= 12345 to the deviceId of your "Now Showing" device created by the plugin
    If you request a record greater than the number of records available 0-total, the action will set the requested number to 0 (the first record)
Bill
Fri Feb 05, 2021 11:57 am
mundmc offline
Thank you for these!
