Inovelli LZW60 4-in-1 motion sensor support request
Forum rules
Fri Nov 06, 2020 4:32 am
nsheldon offline
Hi Matt and Jay.
Back in June I bought an Inovelli LZW60 4-in-1 motion sensor (motion, temperature, humidity, light meter). Unfortunately, Indigo 7.4.1 doesn't support it at all (other than battery updates). I can add the device, but it doesn't even register motion. Enabling Z-Wave debugging shows that messages from it are being received. Battery updates come through just fine and are reflected in the Indigo UI. But motion (and all other status update messages) are just not recognized. I hadn't posted anything earlier because I'd submitted the device data back in June and was hoping the next Indigo update might include support. But since it's been almost 5 months since then, I thought I'd better post something here just as a reminder as I'm sure you're busy and will have forgotten a single Z-Wave device submission out of many I'm sure you've received since then. The device details are below.
Indigo Z-Wave Version: 7.4.1
Node ID: 35
Model: Notification Sensor
Model ID: 000D0001
Manufacturer: Inovelli
Manufacturer ID: 031E
Protocol Version: 6.01
Application Version: 2.03
Model Definition Version: 0
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 80v1 84v2 85v1 86v1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 71v1 6Cv1 70v1 31v5 72v1 73v1 7Av1
Features: routing, battery, beaming, security, waking
Neighbors: 1, 29, 33
Associations: 1:[1] 2:[]
Config Values: - none -
I'm happy to provide additional info if needed.
Thu Nov 12, 2020 4:36 pm
Re: Inovelli LZW60 4-in-1 motion sensor support request
I hope to have definition for this one working in the next version of Indigo (by adding a device definition). In the mean time, follow the instructions on this forum post to create a Trigger on the raw Z-Wave command. That will at least get the motion detecting working for you.
Thu Nov 12, 2020 4:39 pm
nsheldon offline
Got it. Thanks Matt!
Wed Dec 23, 2020 4:55 pm
Indigo 7.5 is now available and includes support for the Inovelli Multi Sensor (LZW60).
