Help converting old iCal script to python
Use this forum to post specific questions you may have when trying to convert an AppleScript to Python. Answers may also include pointers to plugins that would help.
digtrail
Post by digtrail »
I have an old AppleScript that I used to check my iCal for my work schedule using icalbuddy. The script then modifies four different variables based on what is returned. I put this together ages ago from some old examples I had seen here on the forum. I found one or two new python scripts that I might be able to modify but they are much more involved than this old script is. Problem is, I cant figure out how to put this in Python as my coding skills are about 1-2 levels above copy paste at this time of my life. Any help would be greatly appreciated. Thanks.
 set LaString to (do shell script "/usr/local/bin/icalbuddy -nc -ic Work eventsToday")
 if LaString contains "Day Work" then
 	set value of variable "DayWork" to "true"
 else
 	set value of variable "DayWork" to "false"
 end if
 if LaString contains "Night Work" then
 	set value of variable "NightWork" to "true"
 else
 	set value of variable "NightWork" to "false"
 end if
 if LaString contains "OFF" then
 	set value of variable "Off" to "true"
 else
 	set value of variable "Off" to "false"
 end if
 if LaString contains "VAC" then
 	set value of variable "Vac" to "true"
 else
 	set value of variable "Vac" to "false"
 end if
jay (support)
Re: Help converting old iCal script to python
Post by jay (support) »
I have no idea what icalbuddy is, but just a straight port of the script would be something like this (untested of course):
# Substitute anything below that starts with IDOF_ with the actual Indigo ID of the
# specified variable - right click the variable in the Variable List window and select Copy ID
import os
la_string = os.popen('/usr/local/bin/icalbuddy -nc -ic Work eventsToday').read()
if "DayWork" in la_string:
	indigo.variables.updateValue(IDOF_DayWork, value='true')
	indigo.variables.updateValue(IDOF_DayWork, value='false')
if "Night Work" in la_string:
	indigo.variables.updateValue(IDOF_NightWork, value='true')
	indigo.variables.updateValue(IDOF_NightWork, value='false')
if "OFF" in la_string:
	indigo.variables.updateValue(IDOF_Off, value='true')
	indigo.variables.updateValue(IDOF_Off, value='false')
if "VAC" in la_string:
	indigo.variables.updateValue(IDOF_Vac, value='true')
	indigo.variables.updateValue(IDOF_Vac, value='false')
digtrail
Post by digtrail »
Thanks for that. icallbuddy is a tiny little app that I found through the forum here. It will look for events on iCal and then can be imported into Indigo. Worked great until I moved to 7.4 awhile back. Didn't need this script at that time any more, but now I do again.
I updated variable id's and tried a run. I got this return:
Script Error embedded script: 'VariableList' object has no attribute 'updateValue'
embedded script, line 8, at top level
AttributeError: 'VariableList' object has no attribute 'updateValue'
import os
   indigo.variables.updateValue(1422763041, value='true')
   indigo.variables.updateValue(1422763041, value='false')
   indigo.variables.updateValue(15646541, value='true')
   indigo.variables.updateValue(15646541, value='false')
   indigo.variables.updateValue(790632292, value='true')
   indigo.variables.updateValue(790632292, value='false')
   indigo.variables.updateValue(41667262, value='true')
   indigo.variables.updateValue(41667262, value='false')
howartp
Post by howartp »
As a guess, but I’m not at my PC:
Change indigo.variables.updateValue() to indigo.variable.updateValue()
ie make variables singular.
jay (support)
Yep, I think that's it. Stumbled over my own cleverness (I proposed the variables vs variable naming scheme, which I've come to regret somewhat).
digtrail
Post by digtrail »
It runs now. BUT it doesn't do anything. So I tried to run icalbuddy direct in terminal and get this in return: bad CPU type in executable: /Users/Kevin/Downloads/icalBuddy-v1.8.8/icalBuddy
My guess is it is now longer compatible. It hasn't been updated for a long time.
Any other ideas on how to parse out daily calendar events ahead of time? I tried playing with cynical calendars but can't seem to figure hour to get it to see the event and modify the variable before the even actually happens. My old script ran at 1201a to look ahead in the day so that the variables would be changed and then other schedules ran later in the day at different times based on that. I searched and there are very few calendar threads here on the forum.
Thanks for the help
digtrail
Post by digtrail »
Nearing success with this. I figured that the bad cpu type was bc I haven't used icalbuddy since before updating to os 10.15 and that it was a 32bit compiled executable. That assumption was right and even tho the original developer hasn't updated it in about 4-5yrs I was able to find an update that works all the way thru 10.17 now by following pull requests on git. Updated version of icalbuddy can be found here: https://github.com/DavidKaluta/icalBuddy64/releases
Installed updated version of icalbuddy and it runs successfully in terminal. However it seems that the script is able to "see" the output as it has in the past bc is it changes all of my variables to false when run in Indigo instead of recognizing that for instance today I am OFF. Any ideas on this? I appreciate the help to this point. Below is output in terminal when run successfully there
Kevin@unifi ~ % icalbuddy -ic Work eventsToday
• Night Work (Work)
    notes: T-2
    ... - 7:00 AM
• Send mask email  (Work)
    6:45 AM - 6:50 AM
• OFF (Work)
    7:00 AM - 11:59 PM
jay (support)
Sorry, left off something important - change this line:
to this:
(I also changed it in my post further up to avoid confusion).
digtrail
Post by digtrail »
That worked. I'm back to automating based on my work schedule. Thanks!
digtrail
Post by digtrail »
Hello all,
Having a new issue with this one. Realized certain schedules didn't seem to be working as should so I checked my variables list and some of those weren't updated as should be. Went to run this script and got this error in event log...
cript Error                    embedded script error:
   Script Error                    'ascii' codec can't decode byte 0xe2 in position 0: ordinal not in range(128)
     embedded script, line 3, at top level
     File '/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/encodings/ascii.py', line 26, in decode
       return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 0: ordinal not in range(128)
Here is the full python script that should run on a schedule...
import os
the_string = os.popen('/usr/local/bin/icalbuddy eventsToday').read()
if "Day Work" in the_string:
   indigo.variable.updateValue(1422763041, value='true')
   indigo.variable.updateValue(1422763041, value='false')
if "Night Work" in the_string:
   indigo.variable.updateValue(15646541, value='true')
   indigo.variable.updateValue(15646541, value='false')
if "OFF" in the_string:
   indigo.variable.updateValue(790632292, value='true')
   indigo.variable.updateValue(790632292, value='false')
if "VAC" in the_string:
   indigo.variable.updateValue(41667262, value='true')
   indigo.variable.updateValue(41667262, value='false')
Any help is appreciated
You should print out "the_string" to the log after reading it in so you can see what's actually there.
import os
indigo.server.log(f"the_string = {the_string}")
digtrail
Post by digtrail »
Tried that. It didn't print out. Returned same script error
digtrail
Post by digtrail »
I'm looking at the GitHub for icalbaddy issues https://github.com/ali-rantakari/icalBuddy/issues and it looks like its going to be a python2 to python3 problem
If you run that command in a Terminal window, what do you get?
Return to “Help Converting from AppleScript”
