miniUniFi Plugin Q&A
Fri Oct 30, 2020 11:07 am
Use this thread for Q&A on the plugin. But reports and Feature requests should be submitted via GitHub:https://github.com/FlyingDiver/Indigo-miniUniFi/issues
Sat Oct 31, 2020 10:45 am
WagnerOne offline
Re: miniUniFi Plugin Q&A
Hi Joe,
Thanks for this. Is it possible to use 2FA with the plugin? I think that is maybe why the plug-in can't talk to my controller, which is a UDM w/ 2FA enabled.
Sat Oct 31, 2020 11:10 am
There's no support for 2FA in the plugin now. I didn't even know that was an option with the UDM (I don't have one).
I can't find any reference to 2FA in any of the client implementations I based the plugin on. Also, I'm seeing comments about the UDM requiring a new 2FA token daily, which would be very inconvenient for a plugin. So don't plan on using the plugin if you have 2FA enabled.
Sat Oct 31, 2020 11:42 am
Just for grins, I'd like to see the error you get back when you try to log in without the 2FA code. Can you turn on debug logging and put the output in a GitHub issue (see above)?
Is it an authenticator based 2FA (automatically updates the code very 30 seconds) or does the server send a code via SMS or email?
Sun Nov 01, 2020 8:42 pm
WagnerOne offline
Thanks.
I opened a Github issue.
It's using authenticator, 30 second style 2FA.
Mike
Sat Jan 23, 2021 10:27 pm
Looking at your code:
lines 262+++
                version = response.json()['meta']['server_version']
            except:
                pass
                newProps = device.pluginProps
                newProps['version'] = version
                device.replacePluginPropsOnServer(newProps)
"version" is not defined in case there is an exception
and "version" is not present when connecting to unifi cloud key controller V6.
https://192.168.1.2:443/proxy/network/status
returns:
<Response [200]> - {"meta":{"rc":"ok","uuid":"xxxxxxx-xxxxx-xxxxxxxx"},"data":[]}
no "version" in the dict.
ps really nicely written code.
Sat Jan 23, 2021 10:29 pm
If there's an exception, the else clause is not executed at all.
And you meant there's no "server_version" key in the dict, right?
Sun Jan 24, 2021 12:16 am
no i misread the "else" as a part of an if, but it is part of the try:/except/else.. your code is correct
