jltnol wrote:Hey Glenn
This is the info on the Fibro device from the "define and sync" tab in Devices:
RGBW Controller (FGRGBWM441), firmware 25.25
didn't even think if this device is supported... as I think I might have had this working at one point, but it's been a year or two, and I honestly don't remember.
Hmmm. That is the same as mine - when you ‘write device details to event log’ can you copy and paste what you get?
Seems to be same as my model but is reporting its name as something different, in the device model bit.
Found it - updated device at my end and indigo has renamed the model - presumably because now the 442 one as well - easy fix for this one.
There is a seemingly newer version - 442 model - which has a different altogether mechanism for selecting built in colours/different parameter value. This 441 seems to be the same.
Will do best to add support for both shortly, once know what is different, and update store.
Glenn
