FINGSCAN - download program
Re: FINGSCAN - download program
posted v 7.24.21 on GitHub https://www.indigodomo.com/pluginstore/72/
= fix: > 5 devices in event
= improved: sort of devcies in event print
= added extended range of network scope from 5 bit (/27 =32 devices ) to 16 bit( /16 = 65k devices ) with any network starting address. Only for folks that have special network configs.
posted v 7.26.25 on GitHub https://github.com/kw123/fingscan & indigo store
added variable "FingEventDevChangedIndigoId" that shows the ID of the last changed device in an event
use this to follow up when an event is triggered which device changed status = which family member came home.
released 7.27.25
added
- send wake on lan packets to ipdevices. It has to be set for each device individually. It "costs" ~ 0.3 secs per device and cycle
- expiration timer to FING up --> down--> expired - set for each device individually in device edit
The info for down / expired is delayed by xx seconds to the plugin. In case FING gets new UP info about the device the timer gets reset.
In a test an iphone 7 and X stayed up for 24 hours w/o interruption when WakeOnLan was enabled too.
This is BEFORE EVENT handling:
FING UP<->DOWN ==> expiration delay (for up->down, reset for down->up)==> device state UP/DOWN ==> EVENTS . There you could do similar things for just one device or many devices in a group
added
posted v 7.27.26
version 7.27.25 had variable FingEventDevChangedIndigoId removed. put back in
developed the new functions (WOL etc) in an older version, now put changes of version .24 into version .26
Karl,
Sorry, but the latest version is giving the following error every few seconds:
error in Line '696' ; error='global name 'init' is not defined'
JP
JP
sorry version 7.27.27 should fix that , was too fast
added new release 7.28.30, see indigo store or GitHub
added option to ignore specific devices or stop adding new devices
new release 7.29.31
sends status broadcasts .. currently used by home away plugin
new release :7.30.36
1. added attrib change for fing.bin to enable running under catalina
2. converted to std indigo logging
will require indigo 7.3 or higher
since I don't use catalina, this is not directly tested. but should work
new release :7.30.37
added auto delete and recreate if variables are not complete or bad.
new release published.
will check fing version and catalina in the next days
Added features / changes in v7.30.41 @ 2019-12-04
1. moved most of initializing code (reading from config, starting fing ..) into thread loop. that enabled time.sleep() to edit config
2. added check if mac number is properly defined in events, or deleted ..added check for "error in Line '2074' "
Added features / changes in v7.30.39 @ 2019-12-04
1. fixed issue at startup when password is not defined
will give user 200 seconds to finish config , then manual reload is required
Added features / changes in v7.31.41 @ 2020-01-10
enabled fing v 5.x for OSX catalina (>=10.15)
you MUST install fing version 5.x for this
either download
https://www.fing.com/products/development-toolkit use OSX button
or use
/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/fingscan.indigoPlugin/Contents/Server Plugin/CLI_macOSX_5.4.0.zip
have attached fing v 5.x in the plugin.
if someone could test?
Added features / changes in v7.31.48 @ 2020-01-11
1. enabled fing v 5.x for OSX catalina (>=10.15)
either download
or use
file in plugin zip: CLI_macOSX_5.4.0.zip
2. enabled print all ip ports menu option for catalina
Added features / changes in v7.31.52 @ 2020-01-23
1. added loggin statement in case empty or bad data is read from indigo prefs file for EVENTS data
Added features / changes in v7.31.53 @ 2020-02-09
1. added suppression of variables SQL logging, available with indigo 7.4.1
