Different headers in my CSV files
Sat May 18, 2019 4:04 pm
norcoscia offline
Question I was looking at some of the CSV files
Some have a value in the header of the second column some say sensor value - is that a problem?
_______
Norm
Sun May 19, 2019 3:52 am
Re: Different headers in my CSV files
Hi Norm - assuming that you're using a CSV Engine device to manage those CSV files, the header of the second column should be whatever you have entered into the 'Title' field for that CSV source. You can manually edit the column header of that file, or delete the file entirely and the plugin will recreate it at the next data refresh point.
Sun May 19, 2019 7:02 am
norcoscia offline
I took a closer look - since the data is coming from various places the choices I have for the drop down seem to be different (depending on the source). If I just leave it I'm assuming all will be fine - you are not using that in any calculations correct?
_______
Norm
Sun May 19, 2019 7:29 am
Yes, that's right--it's not used in any calculations. The header of the second column is only used as a name for the data sources within the chart device settings and within the CSV Engine devices.
Sun May 19, 2019 7:33 am
norcoscia offline
OK, thanks - so if I had a 3 party CSV file the words in the header don't much matter and I could still choose it to graph by picking it when building a graph - only rule is timestamp format and one row of data - Correct?
_______
Norm
Sun May 19, 2019 7:41 am
The rules of thumb are:
  • The first row of the file is the header row. Anything on that line will be treated like a header for its row.
  • The first column is the timestamp value. It should be in the form of YYYY-MM-DD HH:MM:SS.SSSSS, although the plugin should be able to handle other datetime formats.
  • The second column is the data point.
Sun May 19, 2019 7:42 am
norcoscia offline
Cool, thanks!!!!!
_______
Norm
