iRoomba iRobot Plugin
Tue Oct 16, 2018 10:53 pm
MarcoGT offline
Re: iRoomba 980 iRobot Plugin
I plan to buy a roomba, but the 980 would be too expensive for my needs; the 690 would it be fine but I read the firmware v3 is not supported by this plugin.
Any plan to have it supported? I assume only one the 980 will move to v3 too, am I right?
Tue Oct 16, 2018 11:31 pm
GlennNZ offline
Hi
No plans to add support for it - but happy to try; which can be a bit difficult remotely.
Base library seems to not support; but in theory and from what I can tell should remain possible.
Edit:
Further review of other code seems possible but 690 does not support same level of options as i7 and 980. But should be able to shutdown those issues with some debug logging and trial and error which willingly to have a go at.
Remotely possible that new changes to plugin for i7 and i7+ compatibility may actually support 690 already (i7 is on firmware 3 currently)....
remains to be tested....
Glenn
Tue Nov 27, 2018 6:43 am
deuan offline
Re: iRomba 980 iRobot Plugin
Warning, this may be a dumb question.
I am trying to use the get password by pressing and holding the home button but I never hear any beeps and the get password always fails with a time out. I have the correct ip as I have fixed it.
Anyone else know how to get my missing beeps :)
Tue Nov 27, 2018 7:08 am
deuan offline
On a closer look at the logs I see this error and my robot does not play beeps it plays a bunch of tones. ;)
Error (client) timeout waiting for plugin response from com.GlennNZ.indigoplugin.irobot for request UiAction
iRobot-Roomba blid is: 3168061234567890
iRobot-Roomba Password=> :1:0909898988:ZQRaueVQqqqqqqqqq<= Yes, all this string.
iRobot-Roomba Error Error in plugin execution UiAction:
File "plugin.py", line 318, in getRoombaPassword
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 102, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/iRobot-Roomba.indigoPlugin/Contents/Server Plugin/roomba.py", line 225, in get_password
File "/Library/Python/2.7/site-packages/configparser.py", line 1232, in set
File "/Library/Python/2.7/site-packages/configparser.py", line 1219, in _validate_value_types
TypeError: option values must be strings
Any ideas?
Tue Nov 27, 2018 1:44 pm
From reviews my understanding is the 985 is the same brain as the 980, but when I try to get the password and connect the plugin to the 985, it times out. Haven't looked at any logs yet, but curious if this suggests that in fact the 985 isn't compatible.
Tue Nov 27, 2018 2:16 pm
GlennNZ offline
Any ideas?
Will need the whole debug log from you trying to connect.
The good news - is it seems to get the password just something failing further downstream so hopefully will be fixable.
Just restart plugin with all debug options on, try to connect a you have done here and PM me the log and I’ll do my best to fix!
Also would be great to get the {IP}.config file that is saved in Username/Documents/Roomba directory to double check as well.
Glenn
Tue Nov 27, 2018 6:10 pm
ckeyes888 offline
I have a 985 and it works beautifully with the plugin.
Carl
Tue Nov 27, 2018 6:24 pm
GlennNZ offline
Carl
Thanks for the 985 feedback; Good to know.
The timeout is expected - as the handshake with iRoomba takes more time than the Indigo dialog likes. (and preferred not to thread this code off - as is only done once)
But it still should complete correctly and show log message or error otherwise.
(so essntially ignore the timeout box)
Glenn
Tue Nov 27, 2018 9:51 pm
deuan offline
Hi, Here is the debug stuff
iRobot-Roomba Debug checkALlRoombas called.
iRobot-Roomba Debug self.connected equals:False& self.continuous equals:True
iRobot-Roomba Debug getRoombaPassword called: 1294032638
iRobot-Roomba File should equal:/Users/media/Documents/Indigo-iRobotRoomba/10.10.10.44-config.ini
iRobot-Roomba Debug waiting on port: 5678 for data
iRobot-Roomba Debug found 1 Roombas
iRobot-Roomba Make sure your robot (Roomba) at IP 10.10.10.44 is on the Home Base and powered on (green lights on). Then press and hold the HOME button on your robot until it plays a series of tones (about 2 seconds). Release the button and your robot will flash WIFI light.
iRobot-Roomba Debug Received: {
"robotname": "Roomba",
"sku": "R980000",
"nc": 0,
"ver": "3",
"proto": "mqtt",
"ip": "10.10.10.44",
"hostname": "Roomba-3168062401005790",
"sw": "v2.4.6-3",
"mac": "80:C5:F2:CF:D7:A1",
"cap": {
"carpetBoost": 1,
"pp": 1,
"langOta": 1,
"binFullDetect": 1,
"ota": 2,
"maps": 1,
"pose": 1,
"eco": 1,
"multiPass": 2,
"edge": 1,
"svcConf": 1
iRobot-Roomba Debug
Roomba (Roomba) IP address is: 10.10.10.44
iRobot-Roomba blid is: 3168061111111111
iRobot-Roomba Password=> :1:1543305397:ZQRaue1111111111 <= Yes, all this string.
iRobot-Roomba Checking for updates...
iRobot-Roomba Debug Plugin version detected: 0.3.1
iRobot-Roomba Debug Current version is: 0.3.1
iRobot-Roomba Debug Getting latest release from ghawken/Indigo-iRobotRoomba...
iRobot-Roomba Debug GET /repos/ghawken/Indigo-iRobotRoomba/releases/latest
iRobot-Roomba Debug HTTP 200 OK
iRobot-Roomba Debug Latest release is: 0.3.1
iRobot-Roomba No updates are available
I don't appear to have an {ip}.config file, I have search the mac, perhaps I am wrong because I don't use mac's much so i am running on very limited knowledge of the file system.
Duncan
Tue Nov 27, 2018 11:01 pm
GlennNZ offline
Duncan
Great.
Thanks. Give me ten minutes and I'll have a test build ready..
Sorry further question - what iRoomba Model is this?
G
Tue Nov 27, 2018 11:06 pm
deuan offline
it's the 980
Tue Nov 27, 2018 11:29 pm
GlennNZ offline
deuan wrote:
it's the 980
Have you changed some of the output above - specifically adding a whole lot of 1s?
Tue Nov 27, 2018 11:59 pm
deuan offline
Yes, I am unsure of how sensitive the data is.
Wed Nov 28, 2018 12:00 am
deuan offline
just a note, I did not add 1's I too out 10 characters and replaced them with 1's :)
Wed Nov 28, 2018 12:02 am
GlennNZ offline
Sorry - spent the last hour trying to figure out how the blid was a buggered as it was and thought a firmware change....
:shock:
Page 5 of 18 1, 2, 3, 4, 5, 6, 7, 8 ... 18
