pmgendon wrote:it appears that the problem was caused when the roomba changed IP. I assigned a fixed IP to the unit and so far, so good!
keep up the good work,
Good to hear. Does need a fixed ip - but should look at making error more obvious.
Does restart once every 24 hours as found occasional connection to Roomba failed and was only way to reset it completely.
Also I uncommonly get a regularly run of connection failure messages - if fails three times will restart to reset connection. This typically is caused by when the Roomba is dead somewhere and runs out of battery. Also should look at making this a bit more obvious
Glenn
