Plugin SDK- event example?
Sun Apr 22, 2018 5:05 pm
brettlid offline
I'm trying to understand the mechanism to be able to handle events in my plugin. I downloaded the SDK but there doesn't seem to be any examples. Am I missing something? Some simple example would really help.
Sun Apr 22, 2018 5:12 pm
Re: Plugin SDK- event example?
Do you want to handle events created outside the plugin or create events within the plugin?
The second Is done with triggers in the plugin.
Sun Apr 22, 2018 6:13 pm
Yes, as Karl said give us some more details about what you are trying to do and we can get you pointed in the right direction.
Sun Apr 22, 2018 6:54 pm
brettlid offline
Both would be great, but more specifically in response to z-wave notifications the plug in receives. I just don't see any examples of either events in the SDK examples.
Sun Apr 22, 2018 7:16 pm
Colorado4Wheeler offline
Take a look at the Plugin Examples folder in your Indigo installation, there are lots of examples there of varying types that you can refer to.
Sun Apr 22, 2018 7:49 pm
Download and install all the Indigo SDK Examples discussed here (there is a link in the first post).
There is one specifically for catching lower-level Z-Wave packets.
Sun Apr 22, 2018 9:50 pm
the thing with events / riggers is a bit confusing but logical:
A device can create an event OR a plugin can
Then in indigo menu you create a Trigger that listens to events
In the plugin you need to define an event in events.xml :
</Events>
    <Event id="xxxxxaaaaa"><Name>your text for the menu</Name> </Event>
</Events>
and something like this in your code
     def triggerStartProcessing(self, trigger):
        self.triggerList.append(trigger.id)
     def triggerStopProcessing(self, trigger):
        if trigger.id in self.triggerList:
            self.triggerList.remove(trigger.id)
     def triggerEvent(self, eventId):
        for trigId in self.triggerList:
            trigger = indigo.triggers[trigId]
            if trigger.pluginTypeId == eventId:
                indigo.trigger.execute(trigger)
        return
And you trigger it in your plugin with:
self.triggerEvent(u"xxxxxaaaaa")
then the trigger you defined in indigo will be triggered by the event created by the plugin
so:
Plugin defines events and creates an event with a method indigo.triggerexecute(trigger) That event then triggers the indigo trigger you defined in the indigo menu..
It took me some time to understand trigger in the plugin vs trigger in the indigo menu.
very rough overview from my perspective..
ps you need to initialize
self.triggerList =[]
somewhere in startup()
Mon Apr 23, 2018 12:00 am
Also feel free to browse my plugins on here; all the Zwave * Plugins trigger on incoming Zwave values.
Mon Apr 23, 2018 9:30 am
brettlid offline
Thanks to everyone who responded. I'll look thru the SDK examples again, but I didn't see one that included the EVENTS.XML file.
Mon Apr 23, 2018 8:29 pm
You won’t cos there isn’t one. :-)
I presume you’ve seen the docs at http://wiki.indigodomo.com/doku.php?id= ... in_guide&s[]=triggerstartprocessing#eventsxml
Tue Apr 24, 2018 10:34 am
If your plugin defines events that the user would select in the Triggers dialog, then you'd need an Events.xml as that defines the UI the user would use to specify the event. If, however, your plugin only needs to receive Z-Wave events from the server, your plugin doesn't need an Events.xml because it's not defining new events for the plugin's user to specify.
