Suddenly this big chunk of error
Sun Mar 04, 2018 4:11 pm
My Indigo server suddenly restarted for no reason I can tell, and on restarting it I see this (which I don't think is related to the restart.)
   Harmony Hub Error               Error in plugin execution runConcurrentThread:
  File "plugin.py", line 64, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
   Harmony Hub Error               plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sun Mar 04, 2018 4:44 pm
Re: Suddenly this big chunk of error
No, it's related to the GitHub issues everyone is having. Make sure you have the latest version of that plugin. Get it via the store directly, you can't use the built in updater.
Sun Mar 04, 2018 5:29 pm
Thanks and sorry for missing the details of this if it has been mentioned already.
Sun Mar 04, 2018 5:34 pm
Well, I posted about it here: viewtopic.php?f=177&t=20234
But not in the forum for each individual plugin.
