Need Data Please: Various Sensors
Sat Feb 17, 2018 3:48 pm
Colorado4Wheeler offline
If you are using something other than standard motion or contact sensors, and are using more advanced things like CO2 or Air Quality sensors or something like that would you mind posting the output of this script here so I can see how other devices work? While this is for HomeKit integration you don't need to be a HomeKit or plugin user, I just need data.
HomeKit has some really cool sensors that I don't currently have so this output will help a lot.
indigo.server.log(unicode(indigo.devices[DEVICE_ID]))
Mon Feb 19, 2018 6:41 am
Coolcaper offline
Re: Need Data Please: Various Sensors
This is a TKB Home Multisensor. Its a door contact sensor with a temp sensor and as of now, it doesn't update at all in Home. Always shows as 'Open'.
Interactive Shell               address : 33
allowOnStateChange : True
allowSensorValueChange : False
batteryLevel : 100
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwOnOffSensorType
displayStateId : onOffState
displayStateImageSel : MotionSensor
displayStateValRaw : False
displayStateValUi : off
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1416182112
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          AllowOnStateChange : true (bool)
          SupportsBatteryLevel : true (bool)
          SupportsEnergyMeter : false (bool)
          SupportsEnergyMeterCurPower : false (bool)
          SupportsEnergyMeterReset : false (bool)
          SupportsOnState : true (bool)
          SupportsSensorValue : false (bool)
          SupportsStatusRequest : true (bool)
          address : 33 (integer)
          disableStatusLogging : false (bool)
          indigoObjVersion : 6 (integer)
          propsPushTickler : 3 (string)
          tempAlwaysFalse : false (bool)
          userConfigVal003 : 0 (integer)
          userConfigVal004 : 99 (integer)
          userConfigVal005 : 8 (integer)
          userConfigVal006 : 4 (integer)
          userConfigVal008 : 3 (integer)
          userConfigVal009 : 4 (integer)
          userConfigVal010 : 12 (integer)
          userConfigVal011 : 12 (integer)
          userConfigVal012 : 12 (integer)
          userConfigVal013 : 1 (integer)
          userPollAfterActivity : true (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : true (bool)
          userWakeInterval : 1440 (integer)
          version : 1.00 (string)
          zwAppVersMajor : 1 (integer)
          zwAppVersMinor : 0 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
               g2 : (list)
          zwAssociationsMapStr : 1:[1] 2:[] (string)
          zwClassCmdBase : 48 (integer)
          zwClassCmdMap : (dict)
               c112 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
               c49 : 5 (integer)
          zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 70v1 30v1 31v5 72v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 32 (integer)
               Item : 1 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Binary Sensor (routing) (string)
          zwConfigVals : (dict)
               p10 : 12 (integer)
               p11 : 12 (integer)
               p12 : 12 (integer)
               p13 : 1 (integer)
               p3 : 0 (integer)
               p4 : 99 (integer)
               p5 : 8 (integer)
               p6 : 4 (integer)
               p7 : 6 (integer)
               p8 : 3 (integer)
               p9 : 4 (integer)
          zwConfigValsStr : 3:0 4:99 5:8 6:4 7:6 8:3 9:4 10:12 11:12 12:12 13:1 (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
          zwEncryptClassCmdMapStr : - none - (string)
          zwEncryptionStatusStr : Not Supported (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, battery, beaming, waking (string)
          zwLibType : 6 (integer)
          zwManufactureId : 280 (integer)
          zwManufactureName : TKBHome (string)
          zwMeterSubTypeFlags : 0 (integer)
          zwMeterSupportsReset : false (bool)
          zwMeterType : 0 (integer)
          zwModelDefnVers : 2 (integer)
          zwModelId : 131074 (integer)
          zwModelName : Multi Sensor (TSM01) (string)
          zwNodeNeighbors : (list)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 8 (integer)
               Item : 16 (integer)
               Item : 23 (integer)
               Item : 27 (integer)
               Item : 28 (integer)
               Item : 31 (integer)
               Item : 32 (integer)
          zwNodeNeighborsStr : 3, 4, 5, 6, 8, 16, 23, 27, 28, 31, 32 (string)
          zwProtoVersMajor : 3 (integer)
          zwProtoVersMinor : 41 (integer)
          zwShowDumpDevToLog : true (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : false (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : true (bool)
          zwWakeInterval : 1440 (integer)
lastChanged : 2018-02-19 20:01:16
lastSuccessfulComm : 2018-02-19 20:01:16
model : Multi Sensor (TSM01)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
          c112 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
          c49 : 5 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 32 (integer)
          Item : 1 (integer)
          p10 : 12 (integer)
          p11 : 12 (integer)
          p12 : 12 (integer)
          p13 : 1 (integer)
          p3 : 0 (integer)
          p4 : 99 (integer)
          p5 : 8 (integer)
          p6 : 4 (integer)
          p7 : 6 (integer)
          p8 : 3 (integer)
          p9 : 4 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 8 (integer)
          Item : 16 (integer)
          Item : 23 (integer)
          Item : 27 (integer)
          Item : 28 (integer)
          Item : 31 (integer)
          Item : 32 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : False
sensorValue : None
states : States : (dict)
     batteryLevel : 100 (integer)
     batteryLevel.ui : 100% (string)
subModel : Motion
supportsAllOff : False
supportsOnState : True
supportsSensorValue : False
supportsStatusRequest : True
version : 1.00
Mon Feb 19, 2018 6:47 am
Coolcaper offline
Another motion sensor which does not update at all in the Home app is the Everspring SP814:
   Interactive Shell               address : 17
allowOnStateChange : False
batteryLevel : 30
configured : True
description :
enabled : True
errorState :
folderId : 41338987
          AllowOnStateChange : false (bool)
          address : 17 (integer)
          propsPushTickler : 5 (string)
          userConfigVal003 : 6 (integer)
          userConfigVal004 : 10 (integer)
          userConfigVal005 : 10 (integer)
          userConfigVal006 : 15 (integer)
          version : 1.03 (string)
          zwAppVersMinor : 3 (integer)
               g1 : (list)
                    Item : 1 (integer)
               g2 : (list)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 70v1 30v1 71v1 72v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 32 (integer)
               Item : 1 (integer)
               p3 : 6 (integer)
               p4 : 10 (integer)
               p5 : 10 (integer)
               p6 : 15 (integer)
          zwConfigValsStr : 3:6 4:10 5:10 6:15 (string)
          zwManufactureId : 96 (integer)
          zwManufactureName : Everspring (string)
          zwModelDefnVers : 1 (integer)
          zwModelId : 65538 (integer)
          zwModelName : Motion Sensor (SP814) (string)
               Item : 2 (integer)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 16 (integer)
          zwNodeNeighborsStr : 2, 3, 4, 5, 6, 7, 8, 16 (string)
          zwProtoVersMajor : 2 (integer)
          zwProtoVersMinor : 64 (integer)
lastChanged : 2018-02-19 20:45:25
lastSuccessfulComm : 2018-02-19 20:45:25
model : Motion Sensor (SP814)
name : Hallway Motion Sensor
onState : False
          g1 : (list)
               Item : 1 (integer)
          g2 : (list)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 32 (integer)
          Item : 1 (integer)
          p3 : 6 (integer)
          p4 : 10 (integer)
          p5 : 10 (integer)
          p6 : 15 (integer)
          Item : 2 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 16 (integer)
protocol : ZWave
remoteDisplay : True
sensorValue : None
     batteryLevel : 30 (integer)
     batteryLevel.ui : 30% (string)
subModel : Motion Sensor
version : 1.03
Mon Feb 19, 2018 6:54 am
Coolcaper offline
This is for a Zipato Water Detector and it works with Home:
  Interactive Shell               address : 100
batteryLevel : None
configured : True
description :
displayStateImageSel : SensorOff
enabled : True
errorState :
folderId : 41338987
          address : 100 (integer)
          version : 1.07 (string)
          zwClassCmdBase : 0 (integer)
          zwDevSubIndex : 2 (integer)
          zwManufactureId : 316 (integer)
          zwManufactureName : Philio (string)
          zwModelId : 131103 (integer)
          zwModelName : Multi Sensor (PAT02-A) (string)
          zwShowDumpDevToLog : false (bool)
          zwShowMainUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
lastChanged : 2018-02-19 20:53:15
lastSuccessfulComm : 2018-02-19 20:53:15
model : Multi Sensor (PAT02-A)
name : Kitchen Flood Detector
onState : False
protocol : ZWave
sensorValue : None
subModel : Flood
version : 1.07
Mon Feb 19, 2018 6:59 am
Coolcaper offline
Another contact sensor, Vision, which does not update in the Home app:
 Interactive Shell               address : 22
batteryLevel : 100
configured : True
description :
displayStateImageSel : SensorOn
displayStateValRaw : True
displayStateValUi : on
enabled : True
errorState :
folderId : 41338987
          address : 22 (integer)
          version : 4.01 (string)
          zwAppVersMajor : 4 (integer)
          zwAppVersMinor : 1 (integer)
               g1 : (list)
                    Item : 1 (integer)
          zwAssociationsMapStr : 1:[1] (string)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 30v1 71v1 72v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 32 (integer)
               Item : 1 (integer)
          zwConfigValsStr : - none - (string)
          zwLibType : 3 (integer)
          zwManufactureId : 265 (integer)
          zwManufactureName : Vision / Yale (string)
          zwModelDefnVers : 0 (integer)
          zwModelId : 536936707 (integer)
          zwModelName : Binary Sensor (routing) (string)
               Item : 2 (integer)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
          zwNodeNeighborsStr : 2, 3, 4, 7, 8, 18, 19 (string)
lastChanged : 2018-02-19 20:56:55
lastSuccessfulComm : 2018-02-19 20:56:55
model : Binary Sensor (routing)
name : Study Keyboard Sensor
onState : True
          g1 : (list)
               Item : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 32 (integer)
          Item : 1 (integer)
          Item : 2 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
protocol : ZWave
sensorValue : None
     onOffState : on (on/off bool)
subModel :
version : 4.01
Mon Feb 19, 2018 7:04 am
Coolcaper offline
The Aeotec Multisensor, doesn't update in the Home app:
   Interactive Shell               address : 37
batteryLevel : 100
configured : True
description :
displayStateImageSel : MotionSensorTripped
enabled : True
errorState :
folderId : 41338987
          address : 37 (integer)
          propsPushTickler : 2 (string)
          userConfigVal002 : true (bool)
          userConfigVal003 : 240 (integer)
          userConfigVal004 : true (bool)
          userConfigVal111 : 720 (integer)
          userConfigVal255 : false (bool)
          userWakeInterval : 60 (integer)
          version : 1.18 (string)
          zwAppVersMinor : 18 (integer)
               g1 : (list)
                    Item : 1 (integer)
               c112 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
               c49 : 5 (integer)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 32 (integer)
               Item : 1 (integer)
               p101 : 224 (integer)
               p102 : 0 (integer)
               p103 : 0 (integer)
               p111 : 720 (integer)
               p112 : 720 (integer)
               p113 : 720 (integer)
               p2 : 1 (integer)
               p3 : 240 (integer)
               p4 : 1 (integer)
               p5 : 1 (integer)
          zwConfigValsStr : 2:1 3:240 4:1 5:1 101:224 102:0 103:0 111:720 112:720 113:720 (string)
          zwManufactureId : 134 (integer)
          zwManufactureName : Aeon Labs (string)
          zwModelDefnVers : 4 (integer)
          zwModelId : 131077 (integer)
          zwModelName : Multi Sensor (DSB05) (string)
               Item : 2 (integer)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
               Item : 25 (integer)
               Item : 26 (integer)
               Item : 27 (integer)
               Item : 28 (integer)
               Item : 31 (integer)
               Item : 32 (integer)
               Item : 34 (integer)
          zwNodeNeighborsStr : 2, 3, 4, 5, 6, 7, 8, 18, 19, 25, 26, 27, 28, 31, 32, 34 (string)
          zwProtoVersMinor : 28 (integer)
          zwShowPollingUI : true (bool)
          zwWakeInterval : 60 (integer)
lastChanged : 2018-02-19 21:01:08
lastSuccessfulComm : 2018-02-19 21:01:08
model : Multi Sensor (DSB05)
name : Alfresco Motion Sensor
onState : True
          g1 : (list)
               Item : 1 (integer)
          c112 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
          c49 : 5 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 32 (integer)
          Item : 1 (integer)
          p102 : 0 (integer)
          p103 : 0 (integer)
          p2 : 1 (integer)
          p3 : 240 (integer)
          p4 : 1 (integer)
          p5 : 1 (integer)
          Item : 2 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
          Item : 25 (integer)
          Item : 26 (integer)
          Item : 27 (integer)
          Item : 28 (integer)
          Item : 31 (integer)
          Item : 32 (integer)
          Item : 34 (integer)
protocol : ZWave
sensorValue : None
version : 1.18
Mon Feb 19, 2018 11:50 am
ZachBenz offline
Smappee Energy Meter (from Autolog's Smappee Indigo Plugin, which creates Indigo devices that track data provided via Smappee's web API)
batteryLevel : None
configured : True
description : Smappee
deviceTypeId : smappeeElectricity
displayStateId : curEnergyLevel
displayStateImageSel : EnergyMeterOn
displayStateValRaw : 626.4
displayStateValUi : 626 Watts
enabled : True
energyAccumBaseTime : 2018-02-19 00:14:12
energyAccumTimeDelta : 37801
energyAccumTotal : 7.25
energyCurLevel : 626.4
errorState :
folderId : 1853680944
     com.autologplugin.indigoplugin.smappeecontroller : (dict)
          SupportsEnergyMeter : true (bool)
          SupportsEnergyMeterCurPower : true (bool)
          address : E000 (string)
          currencyCode : UKP (string)
          dailyStandingCharge : 0.00 (string)
          hideAlwaysOnPower : true (bool)
          hideEnergyMeterAccumPower : true (bool)
          hideEnergyMeterAccumPowerCost : true (bool)
          hideEnergyMeterCurPower : true (bool)
          kwhUnitCost : 0.00 (string)
          optionsEnergyMeterCurPower : last (string)
          serviceLocationId : <REMOVED> (string)
          serviceLocationName : <REMOVED> (string)
lastChanged : 2018-02-19 10:44:13
lastSuccessfulComm : 2018-02-19 10:44:13
model : Smappee
name : Smappee Electricity V2
ownerProps : com.autologplugin.indigoplugin.smappeecontroller : (dict)
pluginId : com.autologplugin.indigoplugin.smappeecontroller
protocol : Plugin
     accumEnergyTimeDelta : 37801 (integer)
     accumEnergyTimeDelta.ui : 37801 seconds (string)
     accumEnergyTotal : 7.25 (real)
     accumEnergyTotal.ui : 7.250 kWh (string)
     alwaysOn : 626.4000000000001 (real)
     alwaysOn.ui : 442 Watts (string)
     curEnergyLevel : 626.4000000000001 (real)
     curEnergyLevel.ui : 626 Watts (string)
     dailyTotalCost : 0 (real)
     dailyTotalCost.ui :   0 (string)
     smappeeElectricityOnline : true (bool)
     smappeeElectricityOnline.ui : online (string)
subModel : Elec.
supportsStatusRequest : False
version : None
Mon Feb 19, 2018 11:52 am
ZachBenz offline
UPS and Battery Monitor plugin device:
batteryLevel : None
configured : True
description :
deviceTypeId : BatteryMonitor
displayStateId : BatteryLevel
displayStateImageSel : None
displayStateValRaw : 100
displayStateValUi : 100
enabled : True
errorState :
folderId : 1286074342
     com.schollnick.indigoplugin.BatteryMonitor : (dict)
          ACPower : true (bool)
          Model :  (string)
          PowerSource :  (string)
          device_version : 4 (integer)
lastChanged : 2018-02-19 10:49:18
lastSuccessfulComm : 2018-02-19 10:49:18
model : Battery and UPS Monitor
ownerProps : com.schollnick.indigoplugin.BatteryMonitor : (dict)
     Model :  (string)
pluginId : com.schollnick.indigoplugin.BatteryMonitor
protocol : Plugin
     ACPower : AC Power (string)
     BatteryLevel : 100 (string)
     BatteryTimeRemaining : 0 (integer)
     Charging : true (bool)
     Model :  -Smart-UPS 1500 FW:UPS 09.2 / ID=18 (id=17891328) (string)
     PowerSource : AC Power (string)
     TimeDateStamp : Mon Feb 19 10:49:18 2018 (string)
subModel :
version : None
Mon Feb 19, 2018 1:13 pm
siclark offline
I have CO monitors for when I come onboard.
Mon Feb 19, 2018 2:11 pm
siclark offline
Actually, realised my CO sensors are created from my alarm plugin so probably not what you want, although keen to see if my alarm devices workwith HKB.
Sat Mar 03, 2018 12:06 pm
Monoprice Z-wave Garage Door sensor. Indigo creates two grouped devices, a tilt sensor and a tamper sensor. HKB has both of these as motion sensors, which isn't right but I'm not sure what they should be.
address : 11
batteryLevel : None
configured : True
description :
enabled : True
errorState :
folderId : 1421131951
          address : 11 (integer)
          version : 4.84 (string)
          zwDevSubIndex : 1 (integer)
          zwModelId : 537528834 (integer)
          zwModelName : Garage Door Tilt Sensor (ZG8101) (string)
lastChanged : 2018-03-03 12:26:25
lastSuccessfulComm : 2018-03-03 12:26:25
model : Garage Door Tilt Sensor (ZG8101)
name : Single Garage Door Tamper Switch
onState : False
protocol : ZWave
sensorValue : None
subModel : Tamper Switch
version : 4.84
address : 11
batteryLevel : 100
configured : True
description :
enabled : True
errorState :
          zwAppVersMinor : 84 (integer)
               g1 : (list)
                    Item : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c48 : 1 (integer)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 32 (integer)
               Item : 1 (integer)
               Item : 2 (integer)
               Item : 3 (integer)
               Item : 5 (integer)
          zwNodeNeighborsStr : 2, 3, 5 (string)
          zwProtoVersMinor : 52 (integer)
          zwShowManualModifyConfigParmUI : true (bool)
name : Single Garage Door Tilt Sensor
onState : False
          g1 : (list)
               Item : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c48 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 32 (integer)
          Item : 1 (integer)
          Item : 2 (integer)
          Item : 3 (integer)
          Item : 5 (integer)
protocol : ZWave
sensorValue : None
subModel : Tilt Sensor
version : 4.84
Sat Mar 03, 2018 12:08 pm
FortrezZ Z-wave water valve. Identified by HKB as a switch, which is what Indigo has as well. Had to change to Valve.
address : 3
batteryLevel : None
configured : True
description : On is closed (water off)
deviceTypeId : zwRelayType
displayStateImageSel : PowerOff
enabled : True
errorState :
folderId : 1572671614
          SupportsBatteryLevel : false (bool)
          SupportsOnState : false (bool)
          address : 3 (integer)
          propsPushTickler : 1 (string)
          userConfigVal000 : 0 (integer)
          userConfigVal001 : 60 (integer)
          version : 3.00 (string)
          zwAppVersMajor : 3 (integer)
          zwAssociationsMapStr : - none - (string)
          zwClassCmdBase : 37 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c134 : 1 (integer)
               c32 : 1 (integer)
               c34 : 1 (integer)
               c37 : 1 (integer)
          zwClassCmdMapStr : 20v1 22v1 25v1 86v1 70v1 71v1 72v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 16 (integer)
               Item : 0 (integer)
          zwClassName : Relay Switch (string)
               p0 : 0 (integer)
               p1 : 60 (integer)
          zwConfigValsStr : 0:0 1:60 (string)
          zwFeatureListStr : routing, beaming (string)
          zwManufactureId : 132 (integer)
          zwManufactureName : FortrezZ (string)
          zwModelId : 37946112 (integer)
          zwModelName : Water Valve (WV01) (string)
               Item : 2 (integer)
               Item : 5 (integer)
               Item : 14 (integer)
          zwNodeNeighborsStr : 2, 5, 14 (string)
          zwProtoVersMinor : 40 (integer)
          zwWakeInterval : 0 (integer)
lastChanged : 2018-01-11 10:12:10
lastSuccessfulComm : 2018-01-11 10:12:10
ledStates : []
model : Water Valve (WV01)
name : Water Shutoff Valve - Left/West
onState : False
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c134 : 1 (integer)
          c32 : 1 (integer)
          c34 : 1 (integer)
          c37 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 16 (integer)
          Item : 0 (integer)
          p0 : 0 (integer)
          p1 : 60 (integer)
          Item : 2 (integer)
          Item : 5 (integer)
          Item : 14 (integer)
protocol : ZWave
subModel :
version : 3.00
Sat Mar 03, 2018 12:20 pm
Zooz Z-Wave Multi Sensor (ZSE40). Motion, Tamper, Temp, Humidity, Luminance. Motion and Luminance were the only ones correctly identified by HBK. Well, there's no good choice for Tamper that I can think of. Maybe Contact Sensor? Is that supposed to represent an alarm system sensor?
Motion:
address : 13
batteryLevel : 70
configured : True
description :
enabled : True
errorState :
          address : 13 (integer)
          userConfigVal001 : 1 (integer)
          userConfigVal002 : 5 (integer)
          userConfigVal003 : 5 (integer)
          userConfigVal004 : 5 (integer)
          userConfigVal005 : 3 (integer)
          userConfigVal007 : 3 (integer)
          version : 5.01 (string)
          zwAppVersMajor : 5 (integer)
               g1 : (list)
                    Item : 1 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c132 : 2 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c152 : 1 (integer)
               c32 : 1 (integer)
               c49 : 7 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c94 : 1 (integer)
          zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 7 (integer)
               Item : 1 (integer)
          zwClassName : Notification Sensor (string)
               p1 : 1 (integer)
               p2 : 5 (integer)
               p3 : 5 (integer)
               p4 : 5 (integer)
               p5 : 3 (integer)
               p6 : 4 (integer)
               p7 : 3 (integer)
          zwConfigValsStr : 1:1 2:5 3:5 4:5 5:3 6:4 7:3 (string)
          zwEncryptionStatusStr : Supported but not Enabled (string)
          zwFeatureListStr : routing, battery, beaming, security, waking (string)
          zwModelId : 539042049 (integer)
          zwModelName : Zooz Multi Sensor (ZSE40) (string)
               Item : 14 (integer)
          zwNodeNeighborsStr : 14 (string)
          zwProtoVersMajor : 4 (integer)
          zwProtoVersMinor : 5 (integer)
lastChanged : 2018-03-03 13:06:01
lastSuccessfulComm : 2018-03-03 13:06:01
model : Zooz Multi Sensor (ZSE40)
name : Summer Kitchen - Motion Sensor
onState : False
          g1 : (list)
               Item : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c132 : 2 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c152 : 1 (integer)
          c32 : 1 (integer)
          c49 : 7 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c94 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 7 (integer)
          Item : 1 (integer)
          p1 : 1 (integer)
          p2 : 5 (integer)
          p3 : 5 (integer)
          p4 : 5 (integer)
          p5 : 3 (integer)
          p6 : 4 (integer)
          p7 : 3 (integer)
          Item : 14 (integer)
protocol : ZWave
sensorValue : None
     batteryLevel : 70 (integer)
     batteryLevel.ui : 70% (string)
version : 5.01
Tamper:
address : 13
batteryLevel : None
configured : True
description :
enabled : True
errorState :
name : Summer Kitchen - Tamper
onState : False
protocol : ZWave
sensorValue : None
subModel : Tamper
version : 5.01
Temperature:
address : 13
batteryLevel : None
configured : True
description :
deviceTypeId : zwValueSensorType
displayStateId : sensorValue
displayStateImageSel : TemperatureSensor
displayStateValRaw : 78.23
displayStateValUi : 78.23 °F
enabled : True
errorState :
          SensorUnits : 2 (integer)
          SupportsSensorValue : true (bool)
          disableStatusLogging : true (bool)
          modelNameAndFirmware : Zooz Multi Sensor (ZSE40), firmware 5.01 (string)
          userPollInterval :  (string)
          userPollingEnabled : false (bool)
          userWakeInterval :  (string)
          zwAssociationsMapStr :  (string)
          zwEncryptionStatusStr :  (string)
          zwNodeNeighborsStr :  (string)
name : Summer Kitchen - Temperature
onState : None
protocol : ZWave
sensorValue : 78.23
     sensorValue : 78.230000 (real)
     sensorValue.ui : 78.23 °F (string)
subModel : Temperature
supportsOnState : False
supportsSensorValue : True
version : 5.01
Humidity::
address : 13
batteryLevel : None
configured : True
description :
displayStateImageSel : DehumidifierOff
displayStateValRaw : 21.03
displayStateValUi : 21.03%
enabled : True
errorState :
          SensorUnits : 1 (integer)
          zwDevSubIndex : 3 (integer)
name : Summer Kitchen - Humidity
onState : None
protocol : ZWave
sensorValue : 21.03
     sensorValue : 21.030000 (real)
     sensorValue.ui : 21.03% (string)
subModel : Humidity
version : 5.01
Luminance:
address : 13
batteryLevel : None
configured : True
description :
displayStateImageSel : LightSensor
displayStateValRaw : 100.0
displayStateValUi : 100.00%
enabled : True
errorState :
          zwDevSubIndex : 4 (integer)
name : Summer Kitchen - Luminance
onState : None
protocol : ZWave
sensorValue : 100.0
     sensorValue : 100.000000 (real)
     sensorValue.ui : 100.00% (string)
subModel : Luminance
version : 5.01
Sat Mar 03, 2018 3:58 pm
Actually Tamper plays an important role in HomeKit but it's likely not going to map until I do complications because it's actually a characteristic of almost every sensor device that they have a "fault/tamper" setting and if tripped it will put an exclamation mark on the device and send you notifications (unless you turn that off). Complications are, well, complicated so they haven't made it yet but are pretty much #1 on my list of things to get implemented.
Sat Mar 03, 2018 4:06 pm
OK, good to hear. Hope the other data is useful.
