- Code: Select all
indigo.server.log(unicode(indigo.devices[DEVICE_ID]))
address : #############
batteryLevel : None
buttonGroupCount : 0
configured : True
description : Opener Device auto-created by MyQ plugin from gateway information
deviceTypeId : myqOpener
displayStateId : onOffState
displayStateImageSel : Locked
displayStateValRaw : True
displayStateValUi : locked
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : #############
com.flyingdiver.indigoplugin.myq : (dict)
IsLockSubType : true (bool)
address : ############# (integer)
devVersCount : 1 (integer)
sensor : ############# (string)
lastChanged : 2018-02-09 16:22:24
lastSuccessfulComm : 2018-02-09 16:22:24
ledStates : []
model : MyQ Door Opener
onState : True
ownerProps : com.flyingdiver.indigoplugin.myq : (dict)
pluginId : com.flyingdiver.indigoplugin.myq
protocol : Plugin
remoteDisplay : True
states : States : (dict)
doorStatus : Closed (string)
doorStatus.Closed : true (bool)
doorStatus.Closing : false (bool)
doorStatus.Disconnected : false (bool)
doorStatus.Open : false (bool)
doorStatus.Opening : false (bool)
doorStatus.Stopped : false (bool)
doorStatus.Unknown : false (bool)
onOffState : on (on/off bool)
onOffState.ui : locked (string)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : None
batteryLevel : None
configured : True
description :
deviceTypeId : zwRelayType
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
errorState :
folderId : 925076314
com.perceptiveautomation.indigoplugin.zwave : (dict)
address : 116 (integer)
indigoObjVersion : 6 (integer)
modelNameAndFirmware : Garage Door Controller (ZW062), firmware 1.11 (string)
propsPushTickler : 9 (string)
tempAlwaysFalse : false (bool)
userConfigVal034 : false (bool)
userConfigVal035 : 13 (integer)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 60 (integer)
version : 1.12 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 12 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
zwAssociationsMapStr : 1:[1] 2:[] (string)
zwClassCmdBase : 102 (integer)
zwClassCmdMap : (dict)
c102 : 1 (integer)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c152 : 1 (integer)
c32 : 1 (integer)
c37 : 1 (integer)
c89 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 25v1 66v1 70v1 71v1 72v1 73v1 5Ev1 98v1 59v1 7Av1 86v1 85v1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 64 (integer)
Item : 7 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Secure Barrier Add-On (string)
zwConfigVals : (dict)
p252 : 0 (integer)
p35 : 13 (integer)
p37 : 16843008 (integer)
p38 : 16843008 (integer)
p39 : 16843008 (integer)
p40 : 16843008 (integer)
p80 : 2 (integer)
zwConfigValsStr : 35:13 37:16843008 38:16843008 39:16843008 40:16843008 80:2 252:0 (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Supported but not Enabled (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, beaming, security (string)
zwLibType : 3 (integer)
zwManufactureId : 134 (integer)
zwManufactureName : Aeon Labs (string)
zwModelDefnVers : 3 (integer)
zwModelId : 33751102 (integer)
zwModelName : Garage Door Controller (ZW062) (string)
zwNodeNeighbors : (list)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 6 (integer)
Item : 8 (integer)
Item : 16 (integer)
Item : 23 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 31 (integer)
Item : 32 (integer)
Item : 37 (integer)
Item : 38 (integer)
Item : 40 (integer)
Item : 45 (integer)
Item : 53 (integer)
Item : 54 (integer)
Item : 98 (integer)
Item : 102 (integer)
Item : 104 (integer)
Item : 105 (integer)
Item : 106 (integer)
Item : 107 (integer)
Item : 109 (integer)
zwNodeNeighborsStr : 3, 4, 5, 6, 8, 16, 23, 27, 28, 31, 32, 37, 38, 40, 45, 53, 54, 98, 102, 104, 105, 106, 107, 109 (string)
zwProtoVersMajor : 3 (integer)
zwProtoVersMinor : 99 (integer)
zwShowDumpDevToLog : true (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : false (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
lastChanged : 2018-02-09 15:24:18
lastSuccessfulComm : 2018-02-09 15:24:18
ledStates : []
model : Garage Door Controller (ZW062)
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
c102 : 1 (integer)
c112 : 1 (integer)
c113 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c152 : 1 (integer)
c32 : 1 (integer)
c37 : 1 (integer)
c89 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 64 (integer)
Item : 7 (integer)
p252 : 0 (integer)
p35 : 13 (integer)
p80 : 2 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 6 (integer)
Item : 8 (integer)
Item : 16 (integer)
Item : 23 (integer)
Item : 27 (integer)
Item : 28 (integer)
Item : 31 (integer)
Item : 32 (integer)
Item : 37 (integer)
Item : 38 (integer)
Item : 40 (integer)
Item : 45 (integer)
Item : 53 (integer)
Item : 54 (integer)
Item : 98 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
subModel : Door Controller
supportsStatusRequest : False
version : 1.12
Script address : #############
batteryLevel : None
configured : True
enabled : True
errorState :
lastChanged : 2018-02-10 06:26:30
lastSuccessfulComm : 2018-02-10 06:26:30
ledStates : []
name : Garage Door Opener (CG081019AFA9)
onState : True
protocol : Plugin
subModel :
version : None
Feb 15, 2018 at 5:38:00 PM 2/15
HomeKit Bridge Error Attempting to control 'Small Garage Door (CG0838484821)' from HomeKit and have not gotten a response from the Indigo device for at least 10 seconds, aborting command
Z-Wave received "Small Garage Door Tilt Sensor" status update is on
Trigger MyQ Door Sync Issue
Z-Wave received "Small Garage Door Tilt Sensor" status update is off
Z-Wave received "Rack Power Switch" energy total to 430.52 kWh
Feb 15, 2018 at 5:38:35 PM 2/15
Feb 15, 2018 at 5:39:03 PM 2/15
