Plugin restart
Thu Feb 01, 2018 9:30 am
Umtauscher offline
Plugin restart
I have a problem with the Harmony Hub plugin not updating after a day or so.
The plugin is running for some time and suddenly it doesn't report changes in the activities any more.
Then I have to restart the plugin and after a few seconds, the activity state is ok again.
I assume there is some sort of timeout when the hub doesn't report changes to the plugin any more.
Is there a way to set some sort of action that could refresh the hubs client list?
TIA for any hint.
Wilhelm
Thu Feb 01, 2018 3:10 pm
Re: Plugin restart
I'll have to see if there's any way to detect that, so I can do an automatic reconnect. Otherwise an action you could put on a schedule might be best.
Can you create an issue ticket here? https://github.com/FlyingDiver/Indigo-Harmony/issues
Fri Feb 02, 2018 1:22 am
Umtauscher offline
Re: Plugin restart
Thanks , I also thought about a scheduled action. unfortunately I can't think of any action that I could start without disturbing the active action, if there is any.
I wouldn't mind being able to trigger a reload but I think at the moment this isn't possible, right?
This morning I found the plugin unaware of the current actin btw.
i will enter the issue at Github.
cheers
wilhelm
Fri Feb 02, 2018 1:42 am
Umtauscher offline
Re: Plugin restart
Just some additional information.
I have 2 hubs, I last restarted the plugin yesterday afternoon.
This morning both devices showed the wrong state in Indigo which means the connection must have been broken yesterday evening already.
Fri Feb 02, 2018 5:43 am
Re: Plugin restart
Anything in the log about this?
Fri Feb 02, 2018 5:52 am
Umtauscher offline
Re: Plugin restart
No, sorry,
I can see the restart yesterday 16:21
and the restart today 08:09
nothing in between.
Eventlogging is set to "informational messages"
Fri Feb 02, 2018 6:06 am
Umtauscher offline
Re: Plugin restart
I just checked setting the level to "debug"
i get
   Harmony Hub Debug               logLevel = 10
   Harmony Hub Debug               updateFrequency = 86400.0
02.02.2018 12:59:41
   Harmony Hub                     Checking for updates...
   Harmony Hub Debug               Plugin version detected: 7.2.2
   Harmony Hub Debug               Current version is: 7.2.2
   Harmony Hub Debug               Getting latest release from FlyingDiver/Indigo-Harmony...
   Harmony Hub Debug               GET /repos/FlyingDiver/Indigo-Harmony/releases/latest
   Harmony Hub Debug               HTTP 200 OK
   Harmony Hub Debug               Latest release is: 7.2.2
   Harmony Hub                     No updates are available
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event state notify, activityId = 15546603, activityStatus = 3
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event state notify, activityId = -1, activityStatus = 0
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event startActivityFinished, activityId = -1, errorCode = 200, errorString = OK
Then I switched off
and that seems to be the last thing I see.
switching On doesn't do anything any more.
Fri Feb 02, 2018 6:27 am
Umtauscher offline
Re: Plugin restart
... and a second try produces this
02.02.2018 13:21:57
   Trigger                         RX-A3070 standby
02.02.2018 13:22:19
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event state notify, activityId = 15546603, activityStatus = 1
   Trigger                         RX-A3070 on
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event state notify, activityId = 15546603, activityStatus = 2
   Harmony Hub Debug               Harmony Hub Wohnzimmer: messageHandler: Event startActivityFinished, activityId = 15546603, errorCode = 200, errorString = OK
BTW the Trigger for the Receiver Standby and On are created with the GhostXML plugin..
So it seems, sometimes it works sometimes the messages are lost or not sent,
Fri Feb 02, 2018 10:00 am
Woetjes offline
Re: Plugin restart
I have the same 'issue' but it's quite rare, once or twice every two weeks or so. I also noticed when I execute a command from Indigo, there is sometimes a delay of 4-5 seconds before the Harmony executes the action. That's happening more often, couple of times per week. I'll turn on debugging to see if I can spot something.
Sun Feb 04, 2018 7:20 am
Woetjes offline
Re: Plugin restart
Hi Joe,
Below you can find the log when the delay happened. Do you see anything strange?
I took around 30 seconds to start the activity.
2018-02-03 19:28:30.612   Harmony Hub Debug   Living: Harmony Hub: Start Activity - 18968386
2018-02-03 19:29:01.173   Harmony Hub Threaddebug   Living: Harmony Hub: messageHandler: Event connect.stateDigest, child.text = {"sleepTimerId":-1,"runningZoneList":[],"configVersion":168,"activityId":"18968386","errorCode":"200","syncStatus":0,"time":1517613228,"stateVersion":1033,"tzOffset":"3600","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"3600","isSetupComplete":true,"contentVersion":82,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","wifiStatus":1,"activityStatus":1,"runningActivityList":"24822932","tz":"CET-1CEST,M3.4.0,M10.4.0\/3","activitySetupState":false,"updates":{"97":"4.14.112","100":"4.14.112"},"hubUpdate":false,"sequence":false,"accountId":"7827841"}
2018-02-03 19:29:01.174   Harmony Hub Debug   Living: Harmony Hub: messageHandler: Event state notify, activityId = 18968386, activityStatus = 1
2018-02-03 19:29:05.502   Harmony Hub Threaddebug   Living: Harmony Hub: messageHandler: Event connect.stateDigest, child.text = {"sleepTimerId":-1,"runningZoneList":[],"configVersion":168,"activityId":"18968386","errorCode":"200","syncStatus":0,"time":1517613228,"stateVersion":1034,"tzOffset":"3600","mode":3,"hubSwVersion":"4.14.123","deviceSetupState":[],"tzoffset":"3600","isSetupComplete":true,"contentVersion":82,"discoveryServer":"https:\/\/svcs.myharmony.com\/Discovery\/Discovery.svc","wifiStatus":1,"activityStatus":2,"runningActivityList":"24822932","tz":"CET-1CEST,M3.4.0,M10.4.0\/3","activitySetupState":false,"updates":{"97":"4.14.112","100":"4.14.112"},"hubUpdate":false,"sequence":false,"accountId":"7827841"}
2018-02-03 19:29:05.503   Harmony Hub Debug   Living: Harmony Hub: messageHandler: Event state notify, activityId = 18968386, activityStatus = 2
2018-02-03 19:29:05.518   Harmony Hub Threaddebug   Living: Harmony Hub: messageHandler: Event startActivityFinished, child.text = errorCode=200:errorString=OK:activityId=18968386
2018-02-03 19:29:05.519   Harmony Hub Debug   Living: Harmony Hub: messageHandler: Event startActivityFinished, activityId = 18968386, errorCode = 200, errorString = OK
