How to re-connect client / Is it possible? [SOLVED]
Tue Jan 30, 2018 7:34 am
autolog offline
Hi Karl,
In the UniFi Dashboard Client tab, it is possible to click on a reconnect button to force a reconnect to a client device.
Is it possible to do this via the plugin?
Scenario is that I have a problematic LIFX bulb (a downlighter that has a large RSJ beam directly line of sight between it and the UniFi AP) that goes no-ack (MIA) and a reconnect seems to sort out the issue. I can detect when this happens in my LIFX plugin and if I could force a reconnect, it would help resolve my issue. :)
Tue Jan 30, 2018 10:09 am
Re: How to re-connect client / Is it possible?
the plugin does NOT talk to the unifi key ..
if we can do this on the switch , router or AP yes ..
the POE power cycle is done on the switch level though an ssh session .. If you can find something on the discussion forums let me know .. I have not found anything
here is how the power cycle works:
set userID [lindex $argv 0 ]
set password [lindex $argv 1 ]
set ipNumber [lindex $argv 2 ]
set port [lindex $argv 3]
set endToken [lindex $argv 4]
set timeout 10
spawn  ssh $userID@$ipNumber
expect {
    "(yes/no)? " {
        send "yes\n"
        sleep 0.1
        expect "assword: " { send "$password\n"}
    "assword: " {
        send "$password\n"
sleep 1
expect "$endToken" {
    sleep 0.1
    send "telnet localhost 23\r"
    sleep 0.1
    send "enable\r"
    sleep 0.05
    send "configure\r"
    sleep 0.05
    send "interface 0/$port\r"
    sleep 0.05
    send "poe opmode shutdown\r"
    sleep 0.3
    send "poe opmode auto\r"
    sleep 0.05
    send "exit\r"
    sleep 0.05
    send "exit\r"
    sleep 0.05
    send "exit\r"
    sleep 0.05
    send "exit\r"
    sleep 0.05
    send "exit\r"
sleep 0.2
expect eof
Tue Jan 30, 2018 11:37 am
autolog offline
Found this on github: Art-of-WiFi/UniFi-API-client
It is written for PHP and based on some info released by Ubiquiti and some wire-sharking.
There is a Request for an API thread here: API full documentation
Not sure if this is any help? :)
Tue Jan 30, 2018 11:54 am
expect "assword:
Is that anything like an #assToggle? :D
Tue Jan 30, 2018 12:06 pm
Colorado4Wheeler offline
Yes, I think it is...
Wed Jan 31, 2018 4:34 pm
this seem to do the trick:
curl  --insecure -c /tmp/unificookie  --data "{'username':'YOURID','password':'YOURPWD'}" https://YOURIP:8443/api/login
curl  --insecure -b /tmp/unificookie  --data '{"cmd":"kick-sta","mac":"xx:xx:xx:xx:xx:xx"}'  https://YOURIP:8443/api/s/default/cmd/stamgr
1. login and store the login token in/tmp/unificookie ("-c"); "-- insecure" as you likely have not a registered certificate on your cloud-key
2. send cmd kick-sta for mac # xx.xx.xx.... to stamgr with "-b" read cookie
replace "default" with your site name and mac # must be lower case.. and ip and userid / pwd
will add this to the plugin
Wed Jan 31, 2018 9:55 pm
Jon,
try v 7.10.80 it has re-connect as well as block / unblock menus/actions
Thu Feb 01, 2018 1:51 am
autolog offline
Hi Karl,
Brilliant, it works very well. :D
Thank you for doing this, it really is appreciated. :)
Thu Feb 01, 2018 12:26 pm
Re: How to re-connect client / Is it possible? [SOLVED]
looking into adding some more items to it ..
hesitating to add things like shutdown gateway .. setup networks .. they do not make sense to have them automated from indigo
could you check out https://github.com/Art-of-WiFi/UniFi-API-client/blob/master/src/Client.php
which of those makes sense to add?
have added print unifi system device info
Thu Feb 01, 2018 12:50 pm
autolog offline
Hi Karl,
I have had a quick look and not sure how much more needs adding?
I think one really needs a use case for each one to say why it would be useful and what issue it would solve.
You could spend a lot of time adding in function that will never get used. :)
Thu Feb 01, 2018 1:38 pm
Jo,
added 2 easy ones: print client, system device info, health info and fixed a smaller issue with GW device mac#
Sun Feb 04, 2018 3:09 pm
autolog offline
Hi Karl,
Upgraded to 7.10.82 and getting this error when executing an Action to reconnect:
uniFiAP Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1246, in buttonConfirmReconnectCALLBACKaction
File "plugin.py", line 1249, in buttonConfirmReconnectCALLBACK
KeyError: key selectedDevice not found in dict
I selected a LIFX Lamp from the pulldown list. :)
Sun Feb 04, 2018 3:52 pm
sorry for that .. too many options to test .. this one should work:
https://www.dropbox.com/s/ha966s7kubu7k0g/uniFiAP-v-7.10.83.zip?dl=1
will also post the same on GitHub
Sun Feb 04, 2018 4:40 pm
autolog offline
Hi Karl,
Thanks - that fixed it. :)
