dev.enabled in deviceStopComm
Wed Jan 24, 2018 12:00 pm
When dev comm Enabled is unchecked (= set to disable) in indigo main window, deviceStopComm() is called..
dev.enabled is till True .. I guess it is not commEnabled
what sets dev.enabled = False?
also there is no commEnabled in dev
Wed Jan 24, 2018 12:58 pm
Re: dev.enabled in deviceStopComm
How are you looking at dev.enabled? Are you examining it in deviceStopComm()? I think you need to get an updated device object for some changes to show up.
Wed Jan 24, 2018 2:04 pm
I was always under the impression that deviceStopComm() was to allow for anything that needed to be buttoned up *before* comm was disabled, and that dev.enabled would be set to False after deviceStopComm() was finished.
Wed Jan 24, 2018 4:49 pm
Dave is correct – deviceStopComm is called before enabled is set to False. If you need to catch this case then you can use deviceUpdated() since it is passed the old and new device. In this case the old device would have enabled set to True and the new device instance would have it set to False.
