Is it possible to have two Envisalink instaled??
Mon Jan 22, 2018 1:27 pm
jens offline
Hello,
Best regards Jens
Mon Jan 22, 2018 1:56 pm
neilk offline
Re: Is it possible to have two Envisalink instaled??
Jens,
What are you trying to achieve? From memory you can add multiples to the alarm (you can certainly add the DSC official serial board and the envisalink to the same panel). If it is a plug-in instance then I am guessing the same approach you can do for the Hue plugin would work to create a second instance if you have two alarms.
Neil
Mon Jan 22, 2018 2:19 pm
durosity offline
You can definitely have two registered on the keybus, it basically just acts as a keypad (and from memory you can have up to 8, assuming you have the power for it). I’ve got two envisalinks plus a IT-100... one envisalink for Homebridge-envisalink, one for indigo and the IT-100 also connected to indigo using a slightly modified version of the plugin (the envisalink used for things like zone bypass, the IT-100 for virtual keypad and triggers as I find it much faster and more reliable than the envisalink!
Mon Jan 22, 2018 3:14 pm
jens offline
I have two warehouses with 2 pcs DSC alarm system, one of which I run Envisalink, now I want to put one more Envisalink on the other and connect it to Indigo as the other one is, they are on same lan.
//Jens
Mon Jan 22, 2018 4:48 pm
travisc offline
That's not possible with the plugin right now. Supporting that would be a lot of work. The plugin was designed with the assumption there would only be one panel.
Mon Jan 22, 2018 5:18 pm
durosity offline
Well they could just do what I did Travis and modify the plugin to have a different name and ID.. I’ve not had any problems with that.
Mon Jan 22, 2018 8:00 pm
travisc offline
That's true. That's a great work around! :)
Mon Jan 22, 2018 10:33 pm
durosity offline
I’m a frikkin’ genius
Tue Jan 23, 2018 1:15 am
neilk offline
Durosity - We all knew that, maybe a slightly evil genius
Jens this thread details what you would need to do, I did this for my second hue hub
http://forums.indigodomo.com/viewtopic.php?f=31&t=13304&p=141124&hilit=Multiple+hue+hubs#p141124
Tue Jan 23, 2018 3:47 am
durosity offline
Yeah yeah I was just kidding. No need to be mean about it.
Tue Jan 23, 2018 5:33 am
jens offline
Thanks, I will try that when I come home to SWEDEN again... :)
Thu Feb 08, 2018 1:03 pm
jens offline
Works great whith two installed :)
