No devices found
Sun Jan 07, 2018 11:10 am
PatriciaW offline
Re: No devices found
I got the following error when I tested using a trigger to send email when the doorbell was pressed:
Error email reply to address not specified: see Email tab in the Preferences Dialog
Then I changed the preferences and this is what I got:
Error email re-send scheduled in 10 minutes
Nothing else. I suspect this has nothing to do with your plugin so the plugin is working.
Sun Jan 07, 2018 11:13 am
mpoulson offline
Glad it is working. You guessed correctly that the email error is not related to the Ring plugin.
Please let me know if you have any problems or questions with the plugin.
Mike
Fri Jan 12, 2018 11:48 pm
jasonw75 offline
The upgrade did the trick. Thanks!
Sat Jan 13, 2018 6:10 pm
mpoulson offline
Glad things are working.
