Fri Jan 05, 2018 4:20 pm
to JAY/MATT
why can the non custom states / properties not be used in iTouch pages? or how can they be used? e.g. description , lastChanged etc?
before I add extra states, I would like to know if there is an option to do it, or if it is planned or not at all.
thanks
Fri Jan 05, 2018 5:58 pm
I don't understand the question.
Fri Jan 05, 2018 9:50 pm
when setting up an iTouch page there is not option to show
"dev.lastChanged"
only "device.states["xxx"] are available, where xxx are the regular and custom states, no access to property "lastChanged"
it would be nice to be able to show dev.lastChanged on the page with the value of e.g. sensor data (temp, rain,...)
Screen Shot 2018-01-05 at 21.50.40.png (26.2 KiB) Viewed 3075 times
Screen Shot 2018-01-05 at 21.48.23.png (32.66 KiB) Viewed 3076 times
Sat Jan 06, 2018 5:49 am
GlennNZ offline
kw123 wrote:
Glenn,
temp, hum,press, air quality have now min/max today and yesterday coded.
also temp,... states are now numbers.
Still need to do some debugging with number of digits shown (decimal places for raw values )
this might create increased updates for indigo due to rounding differences. e.g. 24.00000001 C should be compared to 24.00 C. That is much easier with strings
for pressure that is different as it has MANY scales mB, TORR, inch HG .. Pascal ...
but it looks good .
Great. Well done and thanks Karl. Must have missed this message yesterday.
Hope you had a good New Year!
Glenn
Sat Jan 06, 2018 1:10 pm
"dev.lastChanged"
it would be nice to be able to show dev.lastChanged on the page with the value of e.g. sensor data (temp, rain,...)l
I believe we have that on the request list, but I'll make sure it's there.
FYI, a much better place to put this type of request would be in the Plugin SDK forum rather than on one of your topics.
Sat Jan 06, 2018 2:07 pm
Yes to other forum ... Was just a request posted by a user here.
Sun Jan 07, 2018 12:25 pm
Glenn,
new plugin released on git hub with your requests.
Wed Jan 10, 2018 4:39 am
GlennNZ offline
kw123 wrote:
Glenn,
Great, thanks Karl. Have been giving it a whirl and all seems to be working really well. (Was giving 48 hours to check updating of yesterday min’s etc)
Thanks again.
Glenn
Wed Jan 10, 2018 9:37 am
Thanks for checking.
Sat Jan 13, 2018 11:29 pm
GlennNZ offline
Hi Karl
Thanks for everything - seemingly going well.
How up are you to further suggestions???
For Example:
- Using locale to set default time/date preferences e.g Day/Month/Year version Month/Day/Year particularly
with locale.
import locale
#set locale to user default locale
 locale.setlocale(locale.LC_ALL, '')
Then
t.strftime('%x')+' '+t.strftime('%X')
To get the default locale specific date and time format?
Which for me gives:
14/01/2018 16:24:22
It is a relatively minor thing (and haven't changed all my plugins yet) but didn't realise was relatively easy to do.
(Edit: although for some reason I yet to debug it does not seem to be consistently applied )
Glenn
Sun Jan 14, 2018 8:38 am
Have think about it. The date is also used to decide time actions
So messing with date stamps is a little more involved.
If we go this route I would prefer to have a variable set in config were the user can define the date string eg like this :
%y-%m-%d %H:%M:%S
Then you can do anything you like. But I still need to check the time comparisons.
also
state eg "created" is only touched once. ==> set up a change method to all states with different date time stamp defs,
the state column has a sub string " up/down/expired month-day HH:HH:SS" to indicate last time status was changed, in a shortened form. the number of blanks is not constant and as this column uses variable length font the number of blanks is not simply a function of number characters.. allowing eg Jan instead of 01 would make that a little more challenging .. cool
Sun Jan 14, 2018 2:09 pm
GlennNZ offline
%y-%m-%d %H:%M:%S
also
Thanks.
I think the user defined date is probably the right way to go (if possible)
Would only need to apply to LastUpdate new time field (so shouldn't have major time actions impact?)
(I am having inconsistent results with locale based %x- works if I run in a debugging console within indigo; but not without console)
Glenn
Sun Jan 14, 2018 7:32 pm
After looking at it I have decided against it.
Changing the date format for historical data is really messy. It is used in various decisions.
Mixing date formats would lead to unpredictable results and could lead to loosing (expiring) beacons ...
sorry
Thu Jan 25, 2018 8:35 pm
coming up:
IR camera (AMG88x33 ) images, triggers .. images available in the plugin
Screen Shot 2018-01-25 at 20.33.36.png (170.3 KiB) Viewed 2735 times
Sat Jan 27, 2018 10:03 am
roquej offline
A heads up, latest version has this error:
calcPostion in Line '9143' has error='float division by zero'
JP
Page 63 of 78 1 ... 60, 61, 62, 63, 64, 65, 66 ... 78
