Z-Wave Error failed to get module 003 info from controller (LowLevelBadParameterError -- copyFrom source and destination type mismatch (object may have changed classes))
Z-Wave Error failed to get module 005 info from controller (LowLevelBadParameterError -- copyFrom source and destination type mismatch (object may have changed classes))
Embedded script executor host started
Z-Wave found module included in controller with no matching device (missing or disabled): 014 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 020 - Relay Power Switch
Z-Wave Error module 027 included in controller no longer matches device "Bedroom 1 - Claire's Light" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 7), indigo device type: zwDimmerType (4, 17, 1))
Interface Failure lost connection with interface
Z-Wave Error to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
Trigger Motion: Lounge - Motion Detected
Z-Wave received "023 - Dining - Stella Z TRV" status update battery level 36%
durosity wrote:Oh dear it's getting worse.
shapa wrote:The device is UZB1
durosity wrote:I was thinking it might be nice for a trigger for interface issues.. then if indigo can’t resolve the issues itself it could at the very least send a notification or something to alert us.
Z-Wave Debug SENT requestAlarmSensorStatus: 01 09 00 13 12 02 71 04 25 59 FC
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 05 00 13 59 01 B1 (node NAK)
Z-Wave Error send "Living Room Motion Sensor" status request failed
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "Living Room Motion Sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 12 01 01 6B
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 01 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CF
Z-Wave Debug . . getNodeNeighbors: nodeId 018, neighbors: 1, 21, 24
Z-Wave Syncing - retrieved module neighbors list: 1, 21, 24
Z-Wave Syncing - assigning return route to "018 - Living Room Motion Sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 12 01 AF
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 01 BC
Z-Wave Debug . . assignReturnRoute: node 018, success 0
Z-Wave Error Syncing - failed to assign return route
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 12 24 5B F4
Z-Wave Debug RCVD requestNodeInfo: 01 06 00 49 81 00 00 31
Z-Wave Debug RCVD requestNodeInfo: failed (module asleep or doesn't support command)
Z-Wave Error No response from "018 - Living Room Motion Sensor". Module might be asleep, or is unreachable.
Z-Wave Debug terminatingSyncUI
