Statuses still not updating
Thu Nov 23, 2017 5:12 am
Londonmark offline
Re: Statuses still not updating
I'll check that as soon as I can. Of course at the moment, it's updating statuses perfectly and has been for the last half hour.
Thu Nov 23, 2017 5:16 am
Londonmark offline
OK, as soon as I sent that it tripped up.
The plugin now shows the ZP_CurrentTrack URL as
x-sonos-spotify:spotify%3atrack%3a5pPPEnTGUHrMPu6PAplZuH?sid=9&flags=8224&sn=1
While the script shows:
x-sonos-spotify:spotify%3atrack%3a1YZ4ulk8gxyJvlrq1UGNLm?sid=9&flags=8224&sn=1
So no, they are not the same.
Thu Nov 23, 2017 5:23 am
nlagaros offline
I suspect the track that is playing when it broke has unicode characters in it? If it advances to a track that does not or you play something from your Sonos App that does not, it will go back to updating? That is what I am able to replicate on my end, so I have something to work with.
Will spend a little time on it .. but it is Turkey day here so not sure I will have enough time to figure it out. However, at least I have some idea of what has been going on.
Thu Nov 23, 2017 8:24 am
Londonmark offline
Don't let yourself be taken away from the turkey!
It does seem to manage to kick itself back into life, from time to time. I haven't seen a direct relationship with unicode characters, but I could be missing something. I am now seeing these errors in the log from time to time
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: avTransport subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: renderingControl subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: queue subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Thu Nov 23 11:56:56 2017] [LivingRoom Sonos]: groupManagement subscription failed. Resubscribing..
Thu Nov 23, 2017 9:26 am
nlagaros offline
I do a check every 5 seconds to see if the subscription to events has failed (usually due to a network issue). The protocol is very sensitive. I'd be interested in the timing of these messages. I started working on the unicode issues.
Sun Nov 26, 2017 4:52 pm
nlagaros offline
Mark - I posted another update for you. Give it a shot - should be getting better now...
Mon Nov 27, 2017 6:15 am
Londonmark offline
Thanks Nick - really appreciate it.
Unfortunately we don't seem to be out of the woods yet. I'm not getting any error messages in the Indigo Event Log, but the statuses are still getting stuck. Here is the read-out from the Terminal script:
'AVTransport'
{u'current_crossfade_mode': '1',
 u'current_play_mode': 'SHUFFLE_NOREPEAT',
 u'current_section': '0',
 u'current_track': '2',
 u'current_track_duration': '0:03:05',
 u'current_track_meta_data': <DidlMusicTrack 'Sunny Road' at 0x10bb71ed0>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a5dcfP0DYH5SDeizgbHZop6?sid=9&flags=32&sn=1',
 u'enqueued_transport_uri': 'file:///jffs/settings/savedqueues.rsq#9',
 u'enqueued_transport_uri_meta_data': '',
 u'next_track_meta_data': <DidlMusicTrack 'My Silver Lining' at 0x10bb71810>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3fKg9Up2k4rMBbGgJQnd85?sid=9&flags=32&sn=1',
 u'number_of_tracks': '469',
 u'transport_state': 'TRANSITIONING'}
'AVTransport'
 u'current_track_meta_data': <DidlMusicTrack 'Sunny Road' at 0x10bb95a90>,
 u'next_track_meta_data': <DidlMusicTrack 'My Silver Lining' at 0x10bba6b10>,
 u'transport_state': 'PLAYING'}
'AVTransport'
 u'current_track': '3',
 u'current_track_duration': '0:03:35',
 u'current_track_meta_data': <DidlMusicTrack 'My Silver Lining' at 0x10bbb0350>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3fKg9Up2k4rMBbGgJQnd85?sid=9&flags=32&sn=1',
 u'next_track_meta_data': <DidlMusicTrack 'Tender' at 0x10bbb0710>,
 u'next_track_uri': 'x-file-cifs://Marks-iMac/Music/iTunes/iTunes%20Music/Music/Blur/13/01%20Tender.m4a',
'AVTransport'
 u'current_track': '4',
 u'current_track_duration': '0:07:40',
 u'current_track_meta_data': <DidlMusicTrack 'Tender' at 0x10bb4fed0>,
 u'current_track_uri': 'x-file-cifs://Marks-iMac/Music/iTunes/iTunes%20Music/Music/Blur/13/01%20Tender.m4a',
 u'next_track_meta_data': <DidlMusicTrack 'Felt' at 0x10bb71c90>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3mLA49N1B0U33s2YUDDULc?sid=9&flags=32&sn=1',
It got stuck going from My Sliver Lining to Tender. Skipping to the next track after that does not seem to get it working again.
Mon Nov 27, 2017 6:24 am
Londonmark offline
More info: I just got these errors again and saw the timing:
27 Nov 2017 at 12:20:35
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: avTransport subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: renderingControl subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: zoneGroupTopology subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: queue subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: groupRenderingControl subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: contentDirectory subscription failed. Resubscribing...
Sonos Error [Mon Nov 27 12:20:35 2017] [LivingRoom Sonos]: groupManagement subscription failed. Resubscribing...
The errors came up half way through a song but seem to have had the effect of restoring the correct status information. Here is the output from the Terminal script (with everything that came directly after what I included in my previous post):
'AVTransport'
 u'current_track': '5',
 u'current_track_duration': '0:02:22',
 u'current_track_meta_data': <DidlMusicTrack 'Felt' at 0x10bb83410>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3mLA49N1B0U33s2YUDDULc?sid=9&flags=32&sn=1',
 u'next_track_meta_data': <DidlMusicTrack 'Take Ten' at 0x10bb83250>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3qtpVUsQzvHdMzrmqkdOzP?sid=9&flags=8224&sn=1',
'AVTransport'
 u'current_track_meta_data': <DidlMusicTrack 'Felt' at 0x10bbb0b90>,
 u'next_track_meta_data': <DidlMusicTrack 'Take Ten' at 0x10bbb0b10>,
'AVTransport'
 u'current_track': '6',
 u'current_track_duration': '0:03:08',
 u'current_track_meta_data': <DidlMusicTrack 'Take Ten' at 0x10bb95b90>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3qtpVUsQzvHdMzrmqkdOzP?sid=9&flags=8224&sn=1',
 u'next_track_meta_data': <DidlMusicTrack 'Walking On the Moon' at 0x10bb95750>,
 u'next_track_uri': 'x-file-cifs://Marks-iMac/Music/iTunes/iTunes%20Music/Music/The%20Police/The%20Police_%20Greatest%20Hits/05%20Walking%20On%20the%20Moon.m4a',
'AVTransport'
 u'current_track_meta_data': <DidlMusicTrack 'Take Ten' at 0x10bb83550>,
 u'next_track_meta_data': <DidlMusicTrack 'Walking On the Moon' at 0x10bb83290>,
'AVTransport'
 u'current_track': '7',
 u'current_track_duration': '0:05:01',
 u'current_track_meta_data': <DidlMusicTrack 'Walking On the Moon' at 0x10bb71950>,
 u'current_track_uri': 'x-file-cifs://Marks-iMac/Music/iTunes/iTunes%20Music/Music/The%20Police/The%20Police_%20Greatest%20Hits/05%20Walking%20On%20the%20Moon.m4a',
 u'next_track_meta_data': <DidlMusicTrack 'The Ballad of Davy Crockett' at 0x10bb71dd0>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3nZmtfEjqlqD73tBfnpl1g?sid=9&flags=8224&sn=1',
Hope this is of some help.
Mon Nov 27, 2017 7:33 am
Londonmark offline
After my previous last post, I just left the playlist playing and had no issues at all. I then restarted it to see if it would get stuck again where it had before, and this time it hasn't... It's all updating as it should for now.
