Info on Ikea's new smart bulb offering
Forum rules
Sun Apr 09, 2017 2:07 pm
More of a security evaluation than anything, but it gives more info than any other article I've seen.
It's Zigbee, by the way.
https://mjg59.dreamwidth.org/47803.html
Mon Apr 10, 2017 7:10 am
Re: Info on Ikea's new smart bulb offering
And someone is doing the heavy lifting of building a library to support it in a platform agnostic way:
https://www.reddit.com/r/homeautomation ... we/ikea_trådfri_lights_just_zigbee_and_usable_on/dg2cfbo/
Looks like that unicode character breaks the URL, so you'll have to copy & paste.
Tue Apr 11, 2017 9:55 am
Sun Apr 23, 2017 12:22 pm
Gusten offline
Anyone managed to integrate them in indigo?
Tue Apr 25, 2017 6:37 am
Just thought I'd clarify that while I'm interested in seeing this integrated and found the resources above that I think might help someone do it, I'm in no way qualified to attempt it.
Tue Apr 25, 2017 6:54 am
MarcoGT offline
Well, I would be able to play somehow, but I need the equipment :D
Maybe I am going to to IKEA next week and I will be a couple of bulbs + the gateway (which is needed to control bulbs).
Wed Apr 26, 2017 6:57 am
pvrfan offline
The latest version of Home-Assistant apparently now supports these lights:
The gateway can control lights connected to it and Home Assistant will automatically discover its presence on your network.
https://home-assistant.io/components/tradfri/
Perhaps someone can adapt their code to Indigo?
Craig
Wed May 24, 2017 3:36 pm
Busta999 offline
Any movement on a Plugin for this?
They are a lot cheaper than the equivalent Hue lights.
Fri Nov 24, 2017 3:08 pm
torstein89 offline
Openhab2 also seems to support this, and I have tested it. I would really want to see this supported in Indigo. Bulbs are cheap and work really well.
Fri Nov 24, 2017 4:45 pm
Busta999 offline
They are now by the Hue Plug-in :-)
Sat Nov 25, 2017 2:16 pm
torstein89 offline
I know you could pair them with HUE, but that makes the IKEA remotes, dimmers, and motion sensor not able to talk to the bulbs anymore (correct me if I'm wrong?).
Sent from my SM-G930F using Tapatalk
Sat Nov 25, 2017 3:21 pm
Busta999 offline
I don’t know, I don’t have any Trädfri stuff but this looks like it may help ... https://youtu.be/HFq3xi2fmYY
Thu Nov 30, 2017 3:57 pm
torstein89 offline
Hmm, I could try that, but then I need to get all my IKEA light in short distance to HUE controller and there is now 16 ++ bulbs in various sockets around the house. If the remote controls could act as "hub" to include all connected bulbs it would be a nicer solution, but I cannot make it pair that way with HUE hub.
Thu Nov 30, 2017 4:11 pm
A quick look at the above linked library shows that it requires Python 3. Indigo uses Python 2 so it's likely to be non-trivial to use that library.
Tue Dec 12, 2017 12:42 am
MarcoGT offline
No update on this side?
It could be interesting to have IKEA bulbs integrated :D
