Home Automation gone bad!
Sat Nov 11, 2017 11:48 am
Turribeach offline
The other night a friend of my daughter came over to watch a movie. He is a 5 year old boy. As soon as he heard me switching lights on/off via Alexa with the Alexa Hue Bridge he started to tell Alexa to switch lights on and off and it wasn't funny anymore :? . So I am looking for a way to prevent this in the future. I have coded all my light triggers to use a conditional override variable so that I can disable light triggers individually per light or for all lights. I can then toggle these override variables or the "all lights override" variable in a control page to prevent light triggers from executing. But since the Alexa Hue Bridge toggles the device directly it's bypassing the override variables I created. I could create an Action Group for each light, where I could evaluate my light override variable, and then define a virtual device that I can link in the Alexa Hue Bridge plugin but this seems like a lot of work. I looked at disabling the Alexa Hue Bridge plugin but it not possible (see this thread since you can only restart() plugins. Any suggestions on how to temporarily disable the Alexa Hue Bridge plugin?
Sat Nov 11, 2017 11:54 am
Re: Home Automation gone bad!
Plug Alexa into an Indigo-controlled plug socket?
Sat Nov 11, 2017 12:29 pm
autolog offline
Just disable the Alexa-Hue Bridge device (Comm Enabled column in main UI). :)
That will work, but coincidently, I spotted a bug in the code related to disabled devices :| so you might get an error thrown in the log which you can ignore.
I will release a fix for this in a day or so. :)
Sat Nov 11, 2017 1:40 pm
Turribeach offline
Thanks autolog, that's exactly what I wanted. I created a new variable Alexa_Hue_Bridge_Enabled and used a script on a trigger for value change. I added the variable on a control page as on/off button and presto! I can disable the Alexa integration with the touch of a button. Below is the script in case it helps anyone else:
mydev = indigo.devices[86329839] # "Alexa-Hue Bridge 1"
myvar = indigo.variables[756081712] # "Alexa_Hue_Bridge_Enabled"
if myvar.value == "true":
    indigo.device.enable(mydev, value = True)
    indigo.device.enable(mydev, value = False)
PS: Tested few times and got no errors in the log.
Sat Nov 11, 2017 2:14 pm
Turribeach offline
Actually I spoke too soon. When I disable the Alexa Hue Device it indeed prevents Alexa from interacting with devices but when I try to enable it again then Alexa still says the device it’s unresponsive. Is this the bug you will talking about? A plug-in reload seems to solve the problem.
Sat Nov 11, 2017 4:24 pm
durosity online
There isn’t any voice learning function with Alexa is there? I was hoping amazon (and google) would add something like that after the Burger King debacle earlier in the year. That’d be the ultimate solution to stop unauthorised users hijacking your system!
Sat Nov 11, 2017 4:57 pm
Shutter offline
There's this, but not in the UK yet.
Sat Nov 11, 2017 5:34 pm
For an "automatic" method of triggering this, just use a Fibaro Button, labeled "DO NOT TOUCH" and leave it out where kids can find it.
Sat Nov 11, 2017 5:55 pm
autolog offline
It wasn't, so I will take a look at it and sort it out. :wink:
Thanks for the feedback. :)
Sat Nov 11, 2017 5:58 pm
That’s the kind of thing I was expecting Durosity’s comment to be when I saw his notification pop up earlier.
Sat Nov 11, 2017 6:36 pm
Turribeach offline
It sounds there are still far from what I want, which is to limit Alexa's skills by user profile but I think they will eventually get there. Multiple profiles is also useful, otherwise calendar, tasks, music, etc gets all mixed up. Clearly they are going to get to the point where they have so much context on who's talking that they can figure things out automatically.
Sat Nov 11, 2017 8:28 pm
In the spirit of full disclosure, this would work on me, too.
Sun Nov 12, 2017 2:23 am
durosity online
I occasionally suggest sensible ideas ;)
Sun Nov 12, 2017 4:38 am
noel1983 offline
I’d take a much simpler approach. Put the child outside!
Sun Nov 12, 2017 4:46 am
Turribeach offline
Thanks Noel but I don’t think that Alexa is waterproof or likes being outside.
