Dual Indigo Installations
Sun Nov 05, 2017 2:40 pm
Midnightsun offline
I have indigo installed on a dedicated computer in the furnace room however it would be nice if I could control lighting via my main computer. How can I install it on my main computer without removing it from the dedicated one?
Sun Nov 05, 2017 5:05 pm
Re: Dual Indigo Installations
You may get an error message when you start up the client. There's a bug in the current version when you try to start the client only. Ignore it.
Mon Nov 06, 2017 5:08 am
Note too, that there is an option in the Indigo installer to install the client only. If you run the installer without the client-only install option set, it will install another instance of the server.
Tue Nov 07, 2017 4:21 am
Midnightsun offline
Thanks for all the help. Just need a little more.
When I install using the "use client only" option, I get a window which says "connect to remote indigo server" What am I supposed to fill in to point it to my computer which is running the full version?
Tue Nov 07, 2017 5:03 am
autolog offline
The IP Address of you Apple Mac running the Indigo Server (e.g. 192.168.1.10) or the name of the computer (e.g. My Mac Mini) :)
Tue Nov 07, 2017 6:00 am
On the computer running Indigo (server), look at the "Sharing" pane of System Preferences for "Computers on your local network can access your computer at:"
Thu Nov 09, 2017 6:43 am
Midnightsun offline
Thank you, this worked perfectly for me.
