NEO Coolcam NAS-WS01Z Z-wave Flood Water Leak Alarm Sensor
Tue Oct 17, 2017 12:37 pm
CliveS offline
Thanks to @Lucardos another Neo Z-Wave addition
NEO Coolcam NAS-WS01Z Z wave Flood Water Leak Alarm SensorIndigo Z-Wave Version: 2.0.68
Node ID: 60
Model: Notification Sensor
Model ID: 00031085
Manufacturer: Unknown
Manufacturer ID: 0258
Protocol Version: 4.05
Application Version: 2.54
Model Definition Version: 0
Library Type: 6
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 4, 15, 16, 17, 24, 25, 27, 28, 50, 52
Associations: 1:[1] 2:[] 3:[] 4:[]
Config Values: - none -
NEO COOLCAM NAS-WS01Z Z wave Flood Water Leak Alarm Sensor.jpg (35.2 KiB) Viewed 1593 times
Z-Wave Syncing - started for "060 - water sensor"
Z-Wave Syncing - retrieved module neighbors list: 4, 15, 16, 17, 24, 25, 27, 28, 50, 52
Z-Wave Syncing - assigning return route to "060 - water sensor"
Z-Wave Syncing - retrieved manufacture and model names: Unknown - 0258, Notification Sensor - 00031085
Z-Wave Syncing - retrieved protocol version 4.05, app version 2.54
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Notification Sensor : Notification Sensor (04 : 07 : 01, base 00)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Syncing - device "060 - water sensor" wake interval changed to 60 minutes
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Syncing - retrieved group 3 associations: []
Z-Wave Syncing - retrieved group 4 associations: []
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved battery level of 100%
Z-Wave Syncing - complete
CliveS
Wed Oct 18, 2017 3:41 am
CliveS offline
Re: NEO Coolcam NAS-WS01Z Z-wave Flood Water Leak Alarm Sens
From requesting the Neo Water Sensor definition to being added to 7.1 took
10 hours & 40 minutes
NEO Coolcam NAS-WS01Z Z-wave Flood Water Leak Alarm Sensor by CliveS » Tue Oct 17, 2017 7:37 pm
Indigo 7.1 Release by matt (support) » Wed Oct 18, 2017 6:17 am
Neo CoolCam Water Sensor (WS01Z) - preliminary support.
I apologise to everyone for holding up the 7.1 release ;)
But thanks to Matt & Jay for adding all those NEO devices over the past month and looking at the supported list it is pretty well stocked with the latest devices now.
(But can I again request for 7.1.1 the TKB TZ69E Wall Plug Switch/Meter you added to "The List" in January)
CliveS
Wed Oct 18, 2017 9:54 am
Hah – you definitely got lucky on those. :-)
Tue Aug 03, 2021 9:48 am
macpro offline
I have the new model: NEO Coolcam NAS-WS02Z. But Indigo says it's the WS01Z.
Indigo Z-Wave Version: 7.5.1
Node ID: 96
Model: Water Sensor (WS01Z)
Model ID: 00031085
Manufacturer: Neo
Model Definition Version: 1
Library Type: 6
Neighbors: 1, 4, 5, 8, 9, 12, 15, 16, 19, 20, 21, 22, 23, 24, 25, 26, 28, 29, 30, 33, 35, 38, 39, 40, 51, 66, 67, 69, 70, 72, 80, 84, 85, 86, 90, 91
@Matt: your time starts now :wink:
Tue Aug 03, 2021 2:52 pm
Tue Aug 03, 2021 5:36 pm
:D Based on the model ID reported, it definitely looks like they neglected to update it for the newer version. Does it seem to be working okay?
Tue Aug 03, 2021 11:32 pm
macpro offline
It does. Indigo had no troubles connecting to it and when I put them on a wet surface Indigo sees that.
