Enable Multi Channel Association
Tue Oct 17, 2017 11:14 am
davinci offline
I need to activate multi channel association for my Z-Uno. How can I do this?
So if I need to set MCA for my device on address 87 I will do what exactly?
0x8E 0x01 ASSOCIATION_GROUP_INDEX 0x00 RECEIVING_NODE_ID RECEIVING_ENDPOINT_INDEX
Is that correct: 0x8E 0x01 0x00 0x87
Tue Oct 17, 2017 11:29 am
Re: Enable Multi Channel Association
Can you move the contents of that post over to this thread and delete the other post? That way we don't have 2 open threads on the same topic to maintain.
Tue Oct 17, 2017 1:49 pm
davinci offline
Done.
Tue Oct 17, 2017 3:07 pm
I'm not sure. Are you trying to add a multi channel association to the Z-Uno so that it sends out an association command to the destination node? Can you detail what is the sending node (Z-Uno) and receiving node (??? your node address 87?).
Wed Oct 18, 2017 1:24 am
davinci offline
Z-UNO (87) should send it to Indigo.
Right now if I send two values from Z-UNO it only sends sensor 1 values. If Isend a status update request it sends all sensors values.
Wed Oct 18, 2017 8:12 pm
I think you want something like this:
0x8E 0x01 ASSOCIATION_GROUP_INDEX 0x00 0x01 0x01
where ASSOCIATION_GROUP_INDEX is the group index on the Z-UNO for that particular sensor. So maybe a 0x01 or 0x02 for that value?
There is no 87 in the command because the command itself is sent to your Z-UNO (which is node 87). The command is telling the Z-UNO to add an association group back to the Z-Stick (the second to last 0x01 is the node ID for the Z-Stick).
Thu Oct 19, 2017 11:17 am
davinci offline
Sending 0x01 did the trick. Thanks!
