how to call a method in the plugin class
Mon Oct 09, 2017 4:42 pm
Re: how to call a method in the plugin class
I'm confused. You are talking about a problem when the plugin is being shutdown ? If so, choose the Disable menu for that plugin, let Indigo try to shut it down then copy/paste the entire Event Log window contents starting with where you performed the disable.
Mon Oct 09, 2017 5:40 pm
when setting down / restart
18:29:13                     -in Line '8062' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13                     - pi2  RPI{u'ipNumberPiSendTo': u'192.168.1.22', u'sendToIndigoSecs': u'90.0', u'piNumberReceived': u'2', u'sensorList': u'Wire18B20*137345691,BLEconnect*65802248,i2cOPT3001*1497048646*68,i2cBMExx*1336842918*119*17,i2cTSL2561*864053974*57,', u'piOnOff': u'1', u'ipNumberPi': u'192.168.1.22', u'piUpToDate': [], u'piDevId': 25018397, u'deltaTime2': 0.3365211486816406, u'output': {u'display': {u'1514723531': [{u'i2cAddress': u'60'}, {u'devType': u'screen'}]}}, u'userIdPi': u'pi', u'rPiVersion': 0, u'deltaTime1': 0.08419489860534668, u'lastMessage': 1507591753.015342, u'enableRebootCheck': u'restartLoop,-', u'passwordPi': u'karl123.', u'input': {u'Wire18B20': {u'137345691': u''}, u'BLEconnect': {u'65802248': u'18:65:90:6A:B9:0D'}, u'i2cOPT3001': {u'1497048646': u''}, u'i2cBMExx': {u'1336842918': u''}, u'DHTxx': {u'1815353069': u''}, u'i2cTSL2561': {u'864053974': u''}}, u'enableiBeacons': u'1', u'sensorRefreshSecs': 20, u'deltaChangedSensor': 5, u'piMAC': u'00:1A:7D:DA:71:14'}
18:29:13                     -in Line '9567' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13                     -warning, ignoring state update: in Line '11448' has error='UnexpectedNullError -- CClientMgr not created'
18:29:13                     -in Line '756' has error='UnexpectedNullError'
18:29:13                     - pi0  RPI{u'ipNumberPiSendTo': u'192.168.1.20', u'sendToIndigoSecs': u'90.0', u'piNumberReceived': u'0', u'sensorList': u'INPUTgpio-1*266587410,i2cBMExx*1491353324*118,BLEsensor*244991166,BLEconnect*65802248,BLEconnect*142616409,BLEconnect*462988504,i2cOPT3001*999157650*68,', u'piOnOff': u'1', u'ipNumberPi': u'192.168.1.20', u'piUpToDate': [], u'piDevId': 1477958849, u'deltaTime2': 0.7487449645996094, u'output': {u'setTEA5767': {u'1800415532': [{u'i2cAddress': u'96'}, {u'devType': u''}]}, u'OUTPUTgpio-1-ONoff': {u'1964742022': [{u'gpio': u'26', u'initialValue': u'up', u'outType': u'0'}]}, u'neopixel': {u'246403135': u''}, u'OUTPUTgpio-1': {u'1752078745': [{u'gpio': u'21', u'initialValue': u'up', u'outType': u'0'}]}, u'OUTPUTgpio-4': {u'567118407': [{u'gpio': u'21', u'initialValue': u'x', u'outType': u'0'}, {u'gpio': u'20', u'initialValue': u'x', u'outType': u'0'}, {u'gpio': u'16', u'initialValue': u'-', u'outType': u'0'}, {u'gpio': u'12', u'initialValue': u'x', u'outType': u'0'}]}, u'display': {u'146308284': [{u'i2cAddress': u'60'}, {u'devType': u'st7735'}], u'1160879538': u'', u'1040812751': [{u'i2cAddress': u'60'}, {u'devType': u'screen'}], u'748719371': [{u'i2cAddress': u'39'}, {u'devType': u'LCD1602'}]}}, u'userIdPi': u'pi', u'rPiVersion': 0, u'deltaTime1': 0.03413701057434082, u'lastMessage': 1507591753.855757, u'enableRebootCheck': u'restartLoop,-', u'passwordPi': u'karl123.', u'input': {u'INPUTgpio-1': {u'688656134': [{u'count': u'off', u'gpio': u'21', u'inpType': u'low'}], u'266587410': [{u'count': u'off', u'gpio': u'16', u'inpType': u'high'}]}, u'i2cBMExx': {u'1491353324': u''}, u'BLEsensor': {u'244991166': u''}, u'BLEconnect': {u'65802248': u'18:65:90:6A:B9:0D', u'142616409': u'FC:E9:98:49:BB:E9', u'462988504': u'AC:29:3A:EC:A9:9F'}, u'i2cOPT3001': {u'999157650': u''}}, u'enableiBeacons': u'1', u'sensorRefreshSecs': 20, u'deltaChangedSensor': 5, u'piMAC': u'5C:F3:70:6D:DA:7A'}
the code for fist error:
line 8062 is
            dev = indigo.devices[self.RPI[unicode(pi)]["piDevId"]]
        except  Exception, e:
                self.ML.myLog("all", u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
                self.ML.myLog("all", u" pi" + unicode(pi)+"  RPI"+ unicode(self.RPI[unicode(pi)]) )
with
self.ML.myLog(
is
# .logfile handling
import indigo
import os
import sys
import datetime
import time
class MLX():
    def __init__(self):
        self.logFile        = ""
        self.logFileActive  = False
        self.debugLevel     = "all"
        self.maxFileSize    = 20000000
        self.lastCheck      = time.time()
####-----------------  set paramete rs ---------
    def myLogSet(self, **kwargs ):# eg (debugLevel = "abc",logFileActive=True/False ,logFile = "pathToLogFile",  maxFileSize = 10000000)
        for key, value in kwargs.iteritems():
                if key == "logFileActive":
                    self.logFileActive    = value
                elif key == "logFile":
                    self.logFile    = value
                elif key == "debugLevel":
                    self.debugLevel     = value
                elif key == "maxFileSize" :
                    self.maxFileSize     = int(value)
                if len(unicode(e)) > 5:
                    indigo.server.log(u"in Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
    def myLog(self, msgLevel, text, type=""):
        if msgLevel == "" and self.debugLevel != "all": return
        if  time.time() - self.lastCheck > 100:
             self.checkLogFiles()
            if not self.logFileActive:
                if msgLevel == "smallErr":
                    indigo.server.log(u"------------------------------------------------------------------------------")
                    indigo.server.log(text)
                    return
                if msgLevel == "bigErr":
                    indigo.server.log(u"==================================================================================")
                    return
                if msgLevel == "all" or self.debugLevel.find("all") > -1 or self.debugLevel.find(msgLevel) >-1:
                    if type == "":
                        indigo.server.log(text, type=type)
                    return
                return
            else: # print to external logfile
                    if len(self.logFile) < 3: return # not properly defined
                    f =  open(self.logFile,"a")
                        f.close()
                    except:
                        pass
                    return
                    ts = datetime.datetime.now().strftime("%H:%M:%S")
                    if type == u"":
                        f.write((ts+u" "+u" ".ljust(20) +u"-" + text + u"\n").encode("utf8"))
                        f.write((ts+" " +type.ljust(20) +u"-" + text + u"\n").encode("utf8"))
                    f.close()
                    return
                    f.write(u"----------------------------------------------------------------------------------\n")
                    f.write((ts+u" ".ljust(12)+u"-"+text+u"\n").encode("utf8"))
                    f.close()
                    return
                    f.write(u"==================================================================================\n")
                    f.write((ts+u" "+u" ".ljust(12)+u"-"+text+u"\n").encode("utf8"))
                    f.close()
                    return
                return
                try: f.close()
                except: pass
Mon Oct 09, 2017 6:08 pm
after restarting ~ 20 times i finally got some red lines in the log file:
      Reloading plugin "piBeacon 7.67.153"
   Stopping plugin "piBeacon 7.67.153" (pid 32520)
   Script Error                    embedded script: HandlerError -- all request handlers are disabled
   Script Error                    Exception Traceback (most recent call shown last):
     embedded script, line 9, at top level
StandardError: HandlerError -- all request handlers are disabled
   Stopped plugin "piBeacon 7.67.153"
   Starting plugin "piBeacon 7.67.153" (pid 32735)
Mon Oct 09, 2017 6:09 pm
I don't see any messages in there from Indigo Server saying it is trying to (or failing/succeeding) in shutting down the plugin. I'm interested in seeing everything that is logged (from plugin, Indigo Server, etc.).
Mon Oct 09, 2017 6:12 pm
Okay, that makes a bit more sense. It sounds like you have an embedded python script trying to communicate with your plugin? This error:
I think is because the embedded script is trying to communicate with the plugin which has already started shutting down. I'm not sure there is much that can be done about that. But the error is coming from the embedded script, not the plugin.
Mon Oct 09, 2017 7:03 pm
only things I have that are constant running:
2 classes:
A. for logging
B. tcp/ip stack .
some external scripts (Popen() for expect to communicate via ssh ) but they run may be once an hour.
just tested: . if I use the indigo log in my logger class and NOT writing to an external file , there are NO errors..
but writing to a file instead of calling indigo.server.log SHOULD not do anything??
it is this section that is active:
                        f.close()
                    except:
                        pass
                    return
                    if type == u"":
                    f.close()
                    return
                    f.close()
                    return
                    f.close()
                    return
                return
I really don't see anything that is wrong.. and it only happens when the tcpio stack is active..
Mon Oct 09, 2017 9:37 pm
ok this might be it:
this is the loop inside run concurrent ..
        ########   ------- here the loop starts    --------------
        while self.quitNow == "":
                self.countLoop += 1
                self.sleep(5.)
                if self.countLoop > 5:
                    anyChange= self.periodCheck()
                if self.statusChanged ==1:  self.setGroupStatus()
                if self.statusChanged ==2:  self.setGroupStatus(init=True)
                if self.enableFING == "1":
                    if self.updateFING("loop ") == "break": break
        indigo.server.log( u"hello shutting down after While  ...:  loop ")
when restarting the plugin through regular indigo restart command the "hello shutting down after While ...: loop" does not get printed into the log file.
actually no indigo.xxx seems to work after the while loop.
Is this this plugin or in general. I was always under the impression that at the end of while loop one could do some shutdown things..
when shutting it down through setting self.quitNow = "xx" it prints "hello shutting down after While ...: loop"
Mon Oct 09, 2017 9:42 pm
ok I am idiot .. somehow I dropped the try :/ except:
   while True
except: pass
around the while loop.
that took me 3 days to find !!!!
forget everything above.
all things work again ..
Tue Oct 10, 2017 3:45 am
kw123 wrote:
ok I am idiot ..
That's par for the course in my neck of the woods. :)
Tue Oct 10, 2017 11:14 am
Great – I'm glad you figured it out because I didn't have a clue as to what could be going wrong. :P
