Plugin for Aviosys IP9258 IP power switch now available
Wed Aug 24, 2016 8:42 pm
wibbly offline
Re: Plugin for Aviosys IP9258 IP power switch now available
Nick,
Sorry to communicate via this comment section, but I couldn’t find an email address anywhere.
I would like to distribute an Indigo plugin based on your IP9258 work, but I see you’ve reserved rights everywhere inside the code … so thought I should ask.
It’s a plugin for another board they made years ago called the IP9202. It was sold barebones for inclusion in other devices. I have one in a box that I use for some outlets.
Thanks in advance.
Wed Aug 24, 2016 11:33 pm
NickSmith offline
Hi - thanks for asking :)
No problem at all - putting my Indigo code into GitHub has been on my to-do list for ages, so this is a good catalyst for doing that. I should get a chance to do that this weekend, at least for this plugin, so will let you know once I've done that. I've got a couple of fixes in the version I'm running at home so will be a good way of getting those into the released version too.
Cheers
Nick
Sun Aug 28, 2016 3:08 pm
NickSmith offline
Hi - have put a version up into GitHub: https://github.com/smudger4/Indigo-IP9258. Feel free to adapt & extend as desired!
Regards
Nick
Mon Sep 05, 2016 9:23 pm
wibbly offline
Thanks Nick,
Will post my modified IP9202 version soon.
Tue Jun 13, 2017 9:02 am
CliveS offline
Has anyone modified this plugin to work with the Aviosys IP9258HP models, I have tried to do so but I failed with an A+
Tried to put together what I thought would work but no luck and reading the docs on python.org was overloading my brain (whats left!)
What I would like to do is send the following to the Aviosys ,
http://192.168.100.77/SetPower.cgi?P1=0+P2=1+P3=0+P4=1
I have tried the following which I extracted bits from Nicks plugin, more in hope that I could revamp it but failed.
#!/usr/bin/env python2
import urllib
import urllib2
import socket
import string
url_cmd = "http://192.168.100.77/SetPower.cgi?P1=0+P2=1+P3=0+P4=1 + user=admin + pass=12345678"
response = urllib2.urlopen(url_cmd)
response.read()
response.close()
Any help would be appreciated..
CliveS
CliveS
Sun Oct 08, 2017 1:24 am
siclark offline
I'm looking at the HP version as well as cheap on eBay. Did you get this working??
Sun Oct 08, 2017 1:30 am
CliveS offline
No, Python and me don't get on :cry:
I have 3 x 9258HP's sitting in the cupboard gathering dust, I only use 1 standalone to ping Google and reset the modem if it fails 5 times.
CliveS
