Just replaced an old Hunter fan with a new Quorum fan. The Quorum was installed (by 3rd party) with wired control (fan light & speed) in a 3-gang box with 2 SwitchLinc dimmers already installed. The fan works great, the fan wall switch includes a dimmer for the attached lamp, also works well.
Except...
When an Insteon signals are sent in the house, the fan light will strobe (apparently) with the Insteon signals. For example, if the fan light is on 25%, using any Insteon switch in the house causes the fan light to pulse to max brightness with Insteon signals.
I've never had Insteon signals interfere with other hardware, so I'm a little puzzled about how to address. It definitely needs to be corrected, since we will generally use the fan light a reduced output, and the strobing is jarring.
Thoughts?
Jeff
