Alexa Audio Integration
Forum rules
Tue Sep 19, 2017 7:02 pm
Dewster35 offline
Re: Alexa Audio Integration
jay (support) wrote:
And, BTW, even this much used to not work back when I was messing with it last year so they've made some improvements to the bluetooth capabilities in the past year through firmware upgrades.
[/quote]
^ This was a joke man.
Do you have sound flower installed for capturing system audio out?
Wed Sep 20, 2017 10:00 am
Just wanted to make sure that anyone reading this thread for the first time from the start understood the chronology.
I used to, when it was included with Airfoil. Haven't used it since they removed it from the Airfoil install.
Wed Sep 20, 2017 3:22 pm
akimball offline
Excited to here about this capability... 16 total dots throughout the house. Can you say something like "Set the volume to 8 everywhere"? Otherwise, it's every dot at it's usual volume right?
I'm still deciding how to hack the dot's speaker jack in my master bedroom because when the stereo receiver isn't on with the right audio channel selected, that dot won't be heard.
-Al
Wed Sep 20, 2017 5:56 pm
Dewster35 offline
Either that group command isn’t available or I’m not using the proper syntax to invoke it. Couldn’t you just split the audio out to a cheap computer speaker?
Wed Sep 20, 2017 6:31 pm
akimball offline
Thanks. And yes, I could split out the audio to a cheap computer speaker but I'm thinking of popping open a dot and bringing the audio out directly before it gets to the jack's switch... and so when the external speaker's aren't powered I still have the build in dot speaker. To take care of impedance issues I may perhaps require a buffering low noise audio op-amp which I can run with stolen 3.3V from inside the dot.
-Al
Thu Sep 21, 2017 8:45 am
norcoscia offline
I think you could open it up and swap out the connector pin contact for a relay controlled by Indigo - that way you avoid any issues with impedance mismatch since only one thing would be connected at a time, just like the connection from the jack opens and closes as the audio jack is inserted or removed.
I like where you are going with this - I'm knee deep in dots also!
_______
Norm
