WallMote Quad
Wed Aug 23, 2017 8:41 am
Turribeach offline
WallMote Quad
Hi all, I'm looking to purchase a Aeotec WallMote Quad to use them as light dimmers. These are supported on v7.x. Anyone else has had any experience with them already?
Thu Sep 07, 2017 3:59 pm
Turribeach offline
Re: WallMote Quad
91 views but no replies. :(
Seems like it's too new. I am taking the plunge and buying one from Amazon UK since Amazon itself is selling them so I can always return it back. Let me know if you have any specific questions as I am going to try to review it as much as I can.
Thu Sep 07, 2017 4:06 pm
Turribeach offline
Re: WallMote Quad
Found an unboxing video here: https://www.youtube.com/watch?v=m3NtTOOv5jI
Fri Sep 08, 2017 5:42 am
durosity offline
Re: WallMote Quad
Pretty cool... i really wish someone would make a device like this but with wires for hooking up to existing switches. Basically a battery operated 2 or 4 or whatever binary input sensor that can be used with existing styles of switches rather than these lovely but mismatching with existing switch style devices.
Fri Sep 08, 2017 5:50 am
Turribeach offline
Re: WallMote Quad
Not sure if I follow you. Fibaro Switches and Dimmers integrate with existing switches with no problem. Plus this is a touch dimmer, not sure how you would integrate a touch dimmer with an existing switch, you can't touch dim on a regular light switch.
Fri Sep 08, 2017 5:57 am
Re: WallMote Quad
For me the problem is that it works on a "Zed Wave" network and I have a "Zee Wave" network. :D
Actually a nice looking device, but it wouldn't really fit into our install.
Fri Sep 08, 2017 6:11 am
Turribeach offline
Re: WallMote Quad
Granted you are using a different standard but that's the beauty of Indigo, you are locked into a single standard. All you need is the Aeotec USB Z-Stick (which costs less than £ 45 on Amazon UK) and you can add Z-Wave devices. Ultimately you shouldn't need to worry which standard a device is as long as it does what you want and it integrates with Indigo properly.
Fri Sep 08, 2017 6:22 am
autolog offline
Re: WallMote Quad
Turribeach wrote:
... that's the beauty of Indigo, you are locked into a single standard. ...
I presume you meant:
that's the beauty of Indigo, you are NOT locked into a single standard
Fri Sep 08, 2017 8:48 am
Re: WallMote Quad
Sorry - my durosity-style sarcasm didn't land. I was just joking that it was "zed" instead of "zee".
Fri Sep 08, 2017 9:05 am
durosity offline
Re: WallMote Quad
I more just meant a battery based module that can sit behind a grid switch panel to have the same basic effect. Of course as you said it wouldn’t be touch based, but that doesn’t bother me. I just dislike having lots of wall warts that look different :)
Fri Sep 08, 2017 9:06 am
durosity offline
Re: WallMote Quad
No one can match my style of sarcasm or wit. Or lack there of.
Fri Sep 08, 2017 10:04 am
CliveS offline
Re: WallMote Quad
Sorry missed this first time round, yes I have one.
Was going to buy when Vesternet had them at around 50 pounds, then they withdrew them and 4 months later they reappear at 80 odd pounds...
Anyway I bought one, not that impressed really.
It has a habit of talking to the controller and seems every time it does it flashes the + LED's yellow so as I was going to put them next to the bed that got a big fat zero from the other half, she was not impressed with it flashing all night.
I was going to put 5v into them permanently but when you charge them they will not talk to the controller. The only way I can see of doing it is to take the usb cables to a wall wart and plug that into a TBK switch that gets turned on when the WallMote hits say 60% and charge for 2 hours and turn off as you will not be able to see when it reaches 100%.
I cannot seem to get the dimming to work so set it to tap once for 25%, then tap again for 50% then tap once more for 100% on switch 1 and turn off on switch 3 press.
As I have it controlling a Hue bulb I can use Nathan's excellent Hue plugin and ramp to 25>50>100 over 5 seconds.
CliveS
CliveS
Fri Sep 08, 2017 7:44 pm
Re: WallMote Quad
No one got what I meant, so I came close. :D
Sat Sep 09, 2017 12:57 pm
Re: WallMote Quad
I did :-)
I have always wondered what the official pronunciation of Zwave was; is it just down to the local pronunciation of the letter 'z' or is it a 'thing' with a specific pronunciation?
Sat Sep 09, 2017 12:58 pm
durosity offline
WallMote Quad
I’m gonna say it should be zed.. as in Zed’s dead baby, Zed’s dead.
