- Posted on
Thu Apr 12, 2018 7:22 am
noel1983
offline
This looks to be an awesome plugin. Probably me being dense but I can't get it to work.
Looking to have it show 'Unlocked' if x == on else 'Locked' if x == off
This is for a relay controlling a door latch.
Logs show:
File "plugin.py", line 127, in deviceUpdated
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 1179, in deviceUpdated
File "plugin.py", line 110, in deviceStartComm
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 30, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/sensor_adapter.py", line 39, in go
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/pyrescaler/pyrescaler.py", line 103, in format
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/pyrescaler/pyrescaler.py", line 106, in convert
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/simpleeval.py", line 334, in simple_eval
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/simpleeval.py", line 226, in eval
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/simpleeval.py", line 265, in _eval
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/simpleeval.py", line 263, in _eval
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Adapters.indigoPlugin/Contents/Server Plugin/simpleeval.py", line 294, in _eval
NameNotDefined: 'on' is not defined for expression ''Unlocked' if x == on else 'Locked''
Guidance much appreciated
Noel
